Display and camera problem with my laptop !
i dont know exactly what u mean but am gonna try
i have 585 geniune interl CPU 2.16 celeron
2 mega ram
32-bit
and its a clean install not upgrade
my OS is windows 7 ultimate -version 6.1.7100 build 7100
i hope that helps and thanks all for helping
This is what they want you to do:
Look at top of the web page and click on "Quick Links" (across from the Welcome ). Now click on User Control Panel, then Edit Details. In the lefthand column you'll see a listing of links. Under "Your Profile" click on "Edit System Specs". Fill in as many blanks as you can.
dual boot Vista 32 bit and Windows 7 32 bit2 GB
Gateway GT5464
2 GB
Contact support via email - I cant find anything, you either, its the best solution.
XP, Vista, W7 64bit Home PremiumIntel Core Duo 6850 3.0 ghz @ 3.7 ghz4GB Corsair DDR 2 PC-6400Ati 4870 1ghz
Asus P5E
Ati 4870 1ghz
Supreme FX 11
View Sonic VX1962wm
1680 X1050
3 Seagate Sata Drives 160gb 250gb 500gb
Thermaltake 600 watt
NZXT Alpha
3X120cm Fans
Microsoft Digital Media Pro Keyboard
Microsoft Wheel Mouse Optical
1.5Mb to 8Mb/384k
