Solved Power Adapter Problem
ellellell1
Explorer
Power User
9:12 PM
Hi everyone.
I know that this is not really entirely related to a Windows 7 computer and especially to these forums, but I really need some advice on this and it would be great if anyone who has experience in voltage, amps and safety for laptop power adapters would be perfect.
My friend has just traveled down to my house for a week but has foolishly forgot his plug for the power socket on his power adapter. He uses this for his computer. Again unrelated becuase it is an Apple 45W MagSafe2 adapter.
So I was wondering if he could simply use a cord like this one below to plug into the adapter?
The black cord is 2.5A 250V~
The adapter is 100-240V~ 1A
These are both for input.
Any help would be greatly appreciated :).
Toshiba, Satellite L750/0T1
Windows 7 64-bit SP1 (VM)
Intel(R) Core(TM) i7-2670QM CPU @ 2.20GHz (8 CPUs), ~2.2GHz
Intel Corp, PSK2YA-0T102S, Sandy Bridge - 09
4 GB (Expandable to 8 GB)
NVIDIA GeForce GT 525M
Conexant SmartAudio HD & NVIDIA High Definition Audio
2 (Mobile PC Display, Dell E2009W)
1366 x 768 & 1680 x 1050
TOSHIBA MK7575GSX - 698GB (Main Hard Drive)
WD Elements - 1TB (External Hard Drive)
Standard PS/2 Keyboard & Dell SK-8165
Synaptics PS/2 Port TouchPad, Logitech Wireless Mouse M185
Download: 49 Mb/s, Upload: 2 Mb/s 'via Ethernet' (OOKLA)
AVG AntiVirus Free Edition (Outside VM)
Internet Explorer, Google Chrome
Main OS:Windows 10 64-bit
That white 'thing' appears to be for an Apple Macintosh MacBook/MacBook Pro [I have a MacBook Pro] and you might not be able use the black cord due to fit, the V-shaped notch in the black plug would have to let it be inserted. But it probably won't hurt to try as it's still a 110/120Volt source.
The MacBook power adapter also came with a piece that replaced that cord and has the prongs to plug directly into a wall socket/extension cord, maybe it's in his Notebook bag.
Microsoft
Microsoft
Hi Berton, thanks.
I have also just discovered that I have another adapter similar to his one. I just replaced the power socket plug with my one and sloted it into his one and it worked! (The top plug bit)
He said he left his plug bit at home (Really weird why, Its like the most important piece!)
The black plug does fit, I have tried it before so I suppose that would work as well.
Thanks again for your help Berton since this was not the most appropriate post I have made before... :)
You're welcome. One thing to watch on the MacBook is the difference between the straight and right-angle plug [computer end], usually different power ratings.
Microsoft
Microsoft
