Power Options Problem
quincysw
2:59 PM
Hemel Hempstead
I am using Windows 7 32bit and although I am setting the power options to turn off the display after 10 minutes nothing happens and the screen does not turn off
Any help would be much appreciated
regards
Brian
HP ProDesk 400 G2.5 SFF
Windows 7 Professional 64bit
Intel(R) Core(TM) i5-4590S [email protected](4CPU's)~3.0GHz
ASRock N68C-S UCC
8192MB RAM
ATI Radeon HD 5450
Microsoft High Definition Audio Device
HP LE2202x LED Backlit LCD
Maxtor 6 YO8OMO SCSI Disk Device 74.51 GB
20mb
self build
amd phenom x4 9600
asus m2n32-sli deluxe
corsair twinxs 2x2gb
2x nvidia 1gb 8500gt
onboard
23" PB Viseo 233d
maxtor sata 500gb
maxtor sata 320gb
fujitsu sata200gb
oryxx tornado 750w
thermaltake xaser lll
artic freezer64 pro + 7 case fans
Hi
Thanks for the tip. Tried that but unfortunately still the same.
regards
Brian
ASRock N68C-S UCC
8192MB RAM
ATI Radeon HD 5450
20mb
Hello Brian,
What type of display are you using that this is not working for?
Just to make sure, this will only turn off the display(s) after X amount of minutes of no keyboard, mouse, and touchscreen activity on the computer by the user. I know it's silly to say, but I have to verify. :o
If your computer uses a battery, then in your power plan settings, double check to make sure that you have both the On battery and Plugged in "Turn off the display" options set.
Hope this may help,
Hi Shawn
I am using using desktop computer and trying to set the display so that it turns off after 10 minutes. There is no movement of mouse or keyboard.
regards
Brian
ASRock N68C-S UCC
8192MB RAM
ATI Radeon HD 5450
20mb
quincysw,
Control Panel | Power Options | Choose when to turn off the display (in left-hand side list) |
Select the desired time | Save button
AMD A10-4600M
AMD Pumori (Socket FT1)
AMD Radeon HD 7660G
1600x900@60Hz
Standard PS/2 Keyboard
Yes that is exactly what I have been doing but for some reason the display does not turn off
regards
Brian
ASRock N68C-S UCC
8192MB RAM
ATI Radeon HD 5450
20mb
run cmd.exe
type in, followed by hitting ENTER:
powercfg -q > %userprofile%\desktop\powersettings.txt
now type, followed by Enter
EXIT
upload as an attachment the powersettings.txt file that is now on your desktop.
Post the snapshot/file:
Post a File or Screenshot in Seven Forums
AMD A10-4600M
AMD Radeon HD 7660G
1600x900@60Hz
ASRock N68C-S UCC
8192MB RAM
ATI Radeon HD 5450
20mb
quincysw,
Exellent!
Now while I'm studying that file, could you please help us a little further by filling out your system specs? Those specs just might help me and others to make an educated guess at the source of your problem.
Update your SevenForums System Specs
User CP (located on the top menu bar) |
Your Profile | Edit System Spec
(left-hand column)
To gather info, use Speccy (my favorite) or SIW or System Info
ADD the word laptop or desktop or netbook to the
“system manufacturer” block, for example,
Toshiba Satellite L305D notebook.
Provide full windows version info, for example:
Use the “Other Info” block for Optical Reader,
Mouse, touchpad, wifi adapter, speakers, monitor, etc
Scroll down and click on SAVE CHANGES.
thanks,
karl
AMD A10-4600M
AMD Radeon HD 7660G
1600x900@60Hz
Let me know when you have updated your system specs.
karl
AMD A10-4600M
AMD Radeon HD 7660G
1600x900@60Hz
ok have updated system specs as best I can
ASRock N68C-S UCC
8192MB RAM
ATI Radeon HD 5450
20mb
Using SPECCY you will be able to do better.
Reread the procedure I gave.
thanks,
karl
AMD A10-4600M
AMD Radeon HD 7660G
1600x900@60Hz
