Problem selecting Default Audio Device
jackc4321
7:11 AM
I'm having a problem with my sound devices. I plug my headphones in, my headphones work fine in other devices, but my computer still runs the sound through the inbuilt speakers instead of through the headphones. The only program I can run through the headphones is WIndows Media Player because I changed the settings in WMP. All my other applications play sound through the in-built speakers at all times, even when the headphones are plugged in.
I have tried re-installing the latest drivers for my sound card, it's an IDT one. I have also tried to make the headphones my default device when I go into Sound>Playback I click on 'make this the default device' but it doesn't do anything.
I have tried everything and it's very annoying.
Any help would be greatly appreciated.
humm...It sounds strange
Can you try this, don't know if it helps
Right click to the speaker icon on the bottom right of the screen-->choose volume control option--> un-check on the all device currently playing sounds and choose your headphone
Hope it works
Tuan
Lenovo T400 2767 2JU
Microsoft Window 7 Professional 32 bit
Intel Centrino2 vPro
2GB DDR3
ATI Radeon 3400
Conexant 20561 SmartAudio HD
Thinkpad Display
1280x800x49 hertz
Magnisium, Fe, etc..
embeded
54Kb/s
Hi Tuan,
Thanks for the suggestion. Didn't help at all though. I am using the IDT High Definition Audio CODEC if that helps anyone at all.
Hi Tuan,
Does the IDT device have a Control Panel?
If there is a control available it will probably be located there.
Some internal audio systems have options for auto-sensing when a headphone is plugged into the Line-Out jack.
Ap
Assembled in my workshop
Windows 7 Home Premium
Intel Core 2 Duo @ 3.00gHz
Gigabyte GA-P35-S3G
ATI Radeon HD 2600 XT
Acer 1917 (x2)
1280 x 1024 on both monitors
Rosewill 500-watt
Rosewill mid-tower
Macally w/2/USB ports.
Trackman Wheel
Thanks Aphelion. I tried going through the IDT Control Panel but still wouldn't let me select the headphones as the default device. I ended up going into Msconfig and disabling the IDT service in Startup and Services which ended up fixing the problem.
Good job, so the audio card software was working against you?
Well, it wouldn't be the fisrt time that has happened. :rolleyes:
pancenter-
Gigabyte GA-P35-S3G
Acer 1917 (x2)
Rosewill 500-watt
Rosewill mid-tower
Trackman Wheel
