Problem with my Wifi Connection
JoelAugier
10:36 PM
I've got a problem with my wifi. I've move on in a new flat with roommates and they're using a WEP Key for their internet connection. And that's the problem because windows doesn't even ask me to enter the key there is just an error message. I've tried to create manually the connection but it didn't work too. I've found a lot of solution on the internet but none of them worked !
What can i do ? thanks for your answer !
Windows 7 Professionnal 64 bt
Hi JoelAugier and welcome
There are many possibilities. They may be using IPv4 and you IPv6, they Homegroup and you workgroup, etc
Can you ask them either not to use encryption, or use a different one?
We need a lot more information to help you so ask them. We need to know what OS they are using, etc.
Jan
LAPTOP. HP Pavilion dv7-4010TX .
Win 7 Ultimate 64-bit. SP1.
Intel i7 -720QM.[1.6GHz Turbo Boost 2.8GHz. 6MB Cache.]
8 DDR 3 RAM. 1066MHZ
ATI 1024 MB. DDR3. Radeon HD5650
17.3" High Definition Brightview LCD. LED Backlit.
1600 x 900.
640GB
Laptop / notebook.
Logitech Anywhere mouse. MX.
ADSL [ but too slow ]
