Problem with Verbatim USB 3.0 portable drive and USB 3.0 port
lumzi23
2:00 PM
Bought a brand new Verbatim Store 'n' Go Portable HDD. It was to be my first taste of USB 3.0 on my (nearly) year old gaming system. When I connected it had a couple of problems.
1. The first USB 3.0 port (front side) I connected it to kept connecting and disconnecting. So I moved to another.
2. This second (front side) port seemed to work but when I tried to transfer a file it was quite slow.
3. Eventually my computer stopped failing to recognize the drive.
4. Attempts to format or error check the drive when connected to the to the blue USB 3.0 port failed.
5 When I transferred to the USB 2.0 port to error check and format, both worked in in disk management.
6. I also downloaded the USB 3.0 drivers from the Intel site.
7. I think I may have connected something poorly when I initially built the system, however upon opening the system I didn't see anything out of the ordinary. It is my first build so I could be wrong. As far as I know there is only one fairly large connector that connects to a blue USB thingy on my motherboard. The cable is usually blue but mine is black but I was under the impression that this is not unusual. My motherboard is the P8Z77-VLX from Asus and my case is the Cooler Master 690II (RC-6N2A-KNN5, I believe).
(Extra: I also should not that drive shows up as a Toshiba in the device manager. I confirmed by disconnecting and reconnecting it. Also when the drive seems to work normally on USB 2.0 now.)
(Extra 2: OS is Windows 7 64bit and the USB 3.0 ports in the past have worked fine as USB 2.0 ports. The problem [to my eyes] seems to be a USB 3.0 thing specifically)
(Extra 3: I can't seem to find how to enable USB 3.0 in the Bios. I see stuff about USB 3.0 legacy mode and 'Intel USB2.0 EHCI controller' but no USB 3.0 on switch. I have the most recent version of my Bios.)
It is also worth mentioning that the drive dropped a couple of times while still its packaging.
If any assistance could be provided it would be greatly appreciated.
Windows 7 Home Premium 64bitIntel core i5 3570kCorsair Vengance 8GBGigabyte AMD Radeon HD 7950
Custom build
Intel core i5 3570k
P8Z77-V LX
Start by installing the drivers that came with your ASUS motherboard. Why would you install Intel drivers? :confused:
If you don't use a USB3 interconnect cable, you won't get USB3. ALL USB3 cables will have a blue insulator at the plug whether the cable itself is black, green, red, pink or whatever--It's a standard.
Make sure the front panel is capable of USB3. Just because you connect it to a USB3 hub doesn't mean it becomes USB3.
Windows 7 Pro-x64i7-2600 3.4GHz - 3.8GHz Turbo8Gb - 2x4GB, Muskin 991770 PC3-1333Integrated Intel HD 2000
Built 2/11/2011
Windows 7 Pro-x64
Intel DH67BL-B3
Integrated Intel 10.1 HD, RealTek ALC892
Asus LCD VH222H, Haier HL24XSL2a
1920x1080, 1920x1080
Crucial SSD C300-128Gb,
Western Digital WD5002AALX - 500Gb,
Western Digital WD7501AALS - 750Gb
Seasonic 650W 80+ Gold Modular
Rosewill Defender
Stock CPU, Four 120mm case fans, PCH fan added
Logitech EX100 Y-RBH94 Wireless
Logitech EX100 M-RCE95 Wireless
3.0/1.5 Mbs
Microsoft Internet Explorer 11
Antec Veris Premier-Multimedia IR Station,
Cyber Accoustics-3602 Speakers,
AFT XM-5U Card Reader,
Hauppauge TV-HVR-2250,
Sony LX300 USB Turntable
I installed the drivers that came with my motherboard initially but it didn't work (which were labelled Intel in any case). The I installed the Intel drivers (I think) then I installed the latest drivers from Asus' website. Just to be sure I have now reinstalled the USB driver that came with my mobo. Still doesn't work.
Also, the mouth of the USB cable is blue. I have confirmed it.
The front of my case has blue USB ports if that is what you mean (sorry I don't know the tech lingo all that well :().
Custom build
Intel core i5 3570k
P8Z77-V LX
I would ask someone to plug in their USB 3.0. If it works it might be the drive. I don't trust "sliding guts" drives. I got a Verbatim due to the price. But inserting into a tight connector kills my thumb. Plus I think sliding guts is too fragile. I like AData USB 3.0 "gray tube" for physical design.
Windows 7 32 bitAMD 5200+ dual core2 GBNVidia GeForce 6150SE 128 MB
HP Media Center
Windows 7 32 bit
AMD 5200+ dual core
2 GB
CRT
1280x1024
500 GB Sata internal :
PS/2
PS/2 Wheel Mouse
SIIG USB 3.0 PCIexpress card.
I don't know anyone with a USB 3.0. In fact this drive I have is the first one I have probably ever handled.
Edit: I had contacted Verbatim and they gave a firmware updater but it could find the drive. I have now asked them if it is possible to install the firmware needed some other way. I don't know if that is the problem. I'll keep you posted.
Also, about my bios question. Is it unusual not to see an on button for USB 3.0 in the bios?
Custom build
Intel core i5 3570k
P8Z77-V LX
Then try your drive on another PC. Go to the library if need be. If it won't take the update chances are it's dead doornail. Those things aren't very sturdy as they are made as cheaply as manufacturer's can devise.
HP Media Center
Windows 7 32 bit
AMD 5200+ dual core
2 GB
CRT
1280x1024
PS/2
PS/2 Wheel Mouse
I have four Verbatim Store 'n' Go 2TB USB 3.0 drives in use on two desktops and a laptop. I use them for my backups. I've also installed five more of them on other machines for friends and family. They are wonderful, and reliable (no matter what manufacturer's SATA-III drive is inside them), and they are the only such external drives I will buy. I especially appreciate the "Green Button" software that spins them down after 10 minutes of inactivity. I also like the ON/OFF rocker switch on the case, something which is absent on other external USB drives I've seen (e.g. one from Hitachi).
I have two in use on my ASUS P8Z77-V Pro motherboard machine (one's a Samsung drive inside, and the other is a Seagate), plugged into two of the stock rear USB 3.0 ports (with the blue tongue). Note that I'm not using the special-purpose USB ports (e.g. for flashing BIOS), but rather the standard USB 3.0 ports. Nary an issue.
No special drivers whatsoever are required. Plug in the drive, and assuming your Windows 7 is behaving properly it should automatically install whatever it wants to install... which is actually a Microsoft driver for the external USB drive. The USB 3.0 Root Hub is supported by Intel drivers (as part of the chipset support) but this should have been configured as part of the Win7 installation and device discovery when you built your machine. I did opt for an ASUS Turbo Boost USB 3.0 driver myself when installing the ASUS software after Win7's install, which came from ASUS and I think is supposed to improve performance even further.
If things are working properly and you plug it into a USB 2.0 port and the device is correctly recognized, Windows will tell you that you can get better performance if you plug it into a USB 3.0 port.
Don't know what else to say, other than that I've never had any problem with these drives. Also, I've even installed them on older machines (including WinXP) where I've had to install a Transcend TS-PDU3 PCIe USB 3.0 adapter to use them optimally. Again, not a problem.
Windows 7 Pro x64 (1), Win7 Pro X64 (2)i5-3350p 3.1Ghz/6MB-cache (1); E8400 3.0Ghz/6...8GB PC3-12800 DDR3 (1); 4GB PC3-10600 DDR3 (2)ATI HD7750 (1), (see TV cards); ATI R7 250 (2)
Home-built, two systems (1) and (2)
i5-3350p 3.1Ghz/6MB-cache (1); E8400 3.0Ghz/6MB-cache (2)
ASUS P8Z77-V Pro (1); ASUS P5Q3 (2)
Realtek ALC892 HD Audio (1); Realtek ALC1200 HD Audio (2)
Eizo HD2441W LCD, Eizo S2433W (1); Eizo 24" S2433W (2)
1920x1200, 1920x1200 (1); 1920x1200 (2)
(1) 1TB SATA-II (7200RPM), 2x2TB SATA-III (7200RPM), 250GB SATA-III (10000RPM) for OS; 2x2TB external USB 3.0
(2) 320GB SATA-II (7200RPM), 750GB SATA-II (7200RPM), 150GB SATA-II (10000RPM) for OS; 2TB external USB 3.0
Nesteq ECS-6001 600W (1); Nesteq ECS-5001 500W (2)
Acousti-Case 360 (1) and (2)
Noctua NH-U12P SE2 for CPU, 2x120mm case fans (1) and (2)
IBM PS/2 (1) and (2)
Logitech MX Revolution wireless (1); Microsoft wired (2)
100mbps down / 10mbps up
Microsoft Security Essentials; Malwarebyte Anti-Malware Pro
Ceton InfiniTV 4-tuner cablecard-enabled TV card as well as Hauppauge HVR-2250 OTA/ATSC 2-tuner TV card in (1), running under Win7 WMC
It might be helpful if the OP posts a link to the product he's talking about. "Store 'n go" seems to cover a lot of ground.
HP Media Center
Windows 7 32 bit
AMD 5200+ dual core
2 GB
CRT
1280x1024
PS/2
PS/2 Wheel Mouse
Portable Hard Drive 500GB USB 3.0 Black | Store 'n' Go
This is the one.
Edit:
@ dsperber I don't know what the problem is. A part of me is wondering if the issue is with my system.
edit @ miles: I have tried it on my laptop on the USB 2.0 ports and it seems to be working fine. I had also tried it earlier. I don't recall if I found any issues.
Custom build
Intel core i5 3570k
P8Z77-V LX
Tough to rule out damage unless you try it on another machine.
HP Media Center
Windows 7 32 bit
AMD 5200+ dual core
2 GB
CRT
1280x1024
PS/2
PS/2 Wheel Mouse
Sorry, I edit my prev post. I tried it on another machine (my laptop on usb 2.0 [no usb 3.0]) and it seems fine.
Edit: It might be difficult to find a USB 3.0 machine but I will hopefully find one and test it.
Custom build
Intel core i5 3570k
P8Z77-V LX
Custom build
Intel core i5 3570k
P8Z77-V LX
That is not the variety I use.
I use the 2TB versions... available here in the USA.
Yeah, mine is different from that one. Mine is a lot thinner.
Obviously the hard drive inside is different for the 500GB version vs. the 2TB version. Yours could also be a 2.5" style whereas mine could be a 3.5" style.
Anyway, I honestly don't think the problem lies with the drive (unless you damaged its USB 3.0 functionality fatally somehow when you dropped it, which seems impossible to believe).
Edit: I noticed that quite a lot of people seem to have a similar issue. It has something to do with 'eXtensible Host Controller" and the usb cables.
Don't know. The drive comes with a USB 3.0 cable, and I've always used them without incident.
As far as Intel xHCI mode, the BIOS in my P8Z77-V Pro has "smart auto" as the default setting, which enables the feature as "optimized". I've not changed it from its default.
Dunno. I've used that 2TB version for the past few years without any problem whatsoever, in numerous different desktop and laptop machines some with built-in USB 3.0 capability and some where I had to add that PCIe USB 3.0 adapter card.
Sorry... can't help you with any more ideas.
It's cool. I have tried changing my xHCI to 'enabled' from 'Smart Auto' but it did nothing. Others who had Renesas (sp?) controllers instead of intel were able to change in by disabling USB 3.0 power management functions in some Renesas utility program (I think it was a utility program at least). I can find no such option for my intel.
Custom build
Intel core i5 3570k
P8Z77-V LX
