Solved questions about system patchers &theme building in general
Jerry,
I customized my system so that it shows me what files and folders are hardlinks or symlinks. It's harmless. Hardlinks and symlinks (aka symbolic links) basically works the same way as shortcuts, but they are more complex in that the OS recognize them as individual file or folder and not just shortcuts. So if for example I dropped a hardlink on my desktop, my OS will think that it is actually in the desktop although it's original location is different and amazingly enough they don't consume disk space. Those are the basics. :)
Windows 7 Professional x64 | Windows ME | Win...Intel Mobile Core 2 Duo SU7300 @ 1.30GHz3 GB HDDR3 411MHzMobile Intel 4 Series Express Chipset Family
ASUS UL80A
Windows 7 Professional x64 | Windows ME | Windows 8 Dev Preview
ASUSTeK Computer Inc. UL80A (Socket 478)
3 GB HDDR3 411MHz
AU Optronics B140XW02 V1
1366x768
500GB internal
320GB external
cheap keyboard
cheap mouse
Jerry!
I'm trying to test my theme but whenever I activate it, it's always in Classic Mode. How do I test it in Aero?
ASUS UL80A
3 GB HDDR3 411MHz
1366x768
500GB internal
320GB external
cheap keyboard
cheap mouse
Did you use universal theme patcher or UxStyle to enable custom themes?
Jerry
Sager NP9170
Win 7 Pro x64 / Win 10 Pro
CLEVO P170EM
12 GB
Backlite
MSE, Malwarebytes Pro
DESKTOP: Custom-built.
OS: Win 10 Pro x64.
CASE: Rosewill R5.
MOTHERBOARD: Asus Z87-A.
GPU: Nvidia Geforce 650 TI.
PSU: Corsair TX750.
Jerry,
You know from the very beginning that I used UxStyle Core.:)
But I have fixed it now. I just deleted some unnecessary files inside my theme folder.
ASUS UL80A
3 GB HDDR3 411MHz
1366x768
500GB internal
320GB external
cheap keyboard
cheap mouse
Jerry,
This is an update. UxStyle Core is giving me a lot of problems so I switched to Universal Theme Patcher. I'm worried that if I run sfc scan, the patched file will revert to the original and my themes will break. Can you confirm on this?
Anyway, I made some progress on my theme but I have a problem with this:
It's the color of the item-hover/selection. I'm certain that I didn't use those colors (blue and mint green) so I have no idea why it appeared like that. The folder/file select background images are nos. 629-632 and the Themes selection background color are nos. 601-604.
ASUS UL80A
3 GB HDDR3 411MHz
1366x768
500GB internal
320GB external
cheap keyboard
cheap mouse
When you run sfc /scannow it checks and repairs system files so any .dll that have been modified by you or Universal Theme Patcher will revert back to the default.
When UxStyle does not work right you need to switch to the default Aero theme and do the following.
Click on the Start Button type in Services In the search box and then click on Services
Scroll down until you see unsigned themes select it in click on the Stop text and let it stop after that click on Start text and see if that works. Your screen may blink when you do this.
As for the problems you are having with the hover images it must be the way you are editing them that is causing the problem. I am not sure why you are getting a different color either. If you zip up your .msstyles and post it here I will look at it.
Jerry
Sager NP9170
CLEVO P170EM
12 GB
Backlite
OS: Win 10 Pro x64.
CASE: Rosewill R5.
PSU: Corsair TX750.
Jerry,
Yup, I checked if the service is running but no matter what, my custom theme keeps reverting back to classic so I gave up and switched to Universal Theme Patcher. It delayed my theme testing so much so I'll stick with Universal Theme Patcher for a while until I'm finished building my theme.
Anyway, here's my .msstyle file: https://www.dropbox.com/sh/5i4jttxkm2x0xxw/OR7kcdVv6O/Byline.7z
It's still in early phase so there's not much difference yet from the original Aero. I don't want to modify a lot of images without fixing the problems first, so right now I'm stuck. Please take a look at it and tell me what needs to be fixed. :D
ASUS UL80A
3 GB HDDR3 411MHz
1366x768
500GB internal
320GB external
cheap keyboard
cheap mouse
I just looked at your .msstyles and I cannot find what is causing the problem(When testing mine looks the same as your screenshot), those image numbers you listed above I looked at and they look fine, I am going to guess you have a corrupt .msstyles my suggestion would be to start with a new .msstyles and try again.
Jerry
Sager NP9170
CLEVO P170EM
12 GB
Backlite
OS: Win 10 Pro x64.
CASE: Rosewill R5.
PSU: Corsair TX750.
I guess that's okay. Good thing I only have to drag-n-drop the images. :)
Anyway, here's image nos. 516 (buttons) & 517 (radio buttons)
Could you tell which one is "hot", "disabled", "normal", etc.? I numbered them for our convenience.
ASUS UL80A
3 GB HDDR3 411MHz
1366x768
500GB internal
320GB external
cheap keyboard
cheap mouse
Pushbutton:
normal
hot
pressed
disabled
defaulted
defaulted animated
Radio button:
unchecked normal
unchecked hot
unchecked press
unchecked disabled
checked normal
checked hot
checked press
check disabled
Jerry
Sager NP9170
CLEVO P170EM
12 GB
Backlite
OS: Win 10 Pro x64.
CASE: Rosewill R5.
PSU: Corsair TX750.
Here is the start menu.
I will start next week on the Explorer window there are so many elements to it I will probably do it in stages (a few areas at a time).
Jerry
Sager NP9170
CLEVO P170EM
12 GB
Backlite
OS: Win 10 Pro x64.
CASE: Rosewill R5.
PSU: Corsair TX750.
More
anything separated by a "," is because of the DPI setting
Jerry
Sager NP9170
CLEVO P170EM
12 GB
Backlite
OS: Win 10 Pro x64.
CASE: Rosewill R5.
PSU: Corsair TX750.
Jerry,
Thanks for this. :D
By the way, what's the difference between "hot" and "hover" because I can't tell which is which.
ASUS UL80A
3 GB HDDR3 411MHz
1366x768
500GB internal
320GB external
cheap keyboard
cheap mouse
Hot and hover are just about the same, hot can be if something is active or if you move the mouse over it where hover is just a hover. I make hot and hover the same image when making a theme.
Jerry
Sager NP9170
CLEVO P170EM
12 GB
Backlite
OS: Win 10 Pro x64.
CASE: Rosewill R5.
PSU: Corsair TX750.
Here is a another hint on the trackbar track the image is 3 by 3 pixels in each pixel controls that track the very middle pixel is the center of the track all the outside pixels control the outside of the track and each pixel is relative to his position in the track if you would color one corner different than the others just a corner would be that color.
Jerry
Sager NP9170
CLEVO P170EM
12 GB
Backlite
OS: Win 10 Pro x64.
CASE: Rosewill R5.
PSU: Corsair TX750.
Here is Explorer
Jerry
Sager NP9170
CLEVO P170EM
12 GB
Backlite
OS: Win 10 Pro x64.
CASE: Rosewill R5.
PSU: Corsair TX750.
Jerry
Jerry,
Could you explain this further? Or please provide a visual representation? I didn't get it :o
ASUS UL80A
3 GB HDDR3 411MHz
1366x768
500GB internal
320GB external
cheap keyboard
cheap mouse
Jerry
Jerry,
This is zoomed in but should help.
Jerry
Sager NP9170
CLEVO P170EM
12 GB
Backlite
OS: Win 10 Pro x64.
CASE: Rosewill R5.
PSU: Corsair TX750.
Hi Jerry. How do I change the explorer white space into another color?
ASUS UL80A
3 GB HDDR3 411MHz
1366x768
500GB internal
320GB external
cheap keyboard
cheap mouse
The only way I know how to is with Windows Style Builder it's a fill color not a image.
Jerry
Sager NP9170
CLEVO P170EM
12 GB
Backlite
OS: Win 10 Pro x64.
CASE: Rosewill R5.
PSU: Corsair TX750.
