Touchpad and USB does not work after fresh install
ok, understood , I will try, but how to find device id?
windows 7i5 8250u (real quadcore 8 threads)8 gb
lenovo 330s 14
windows 7
8 gb
crucial 1 tb nvme qlc
Windows 7 Home Premium x64Intel Core i3-8130U8GBIntel-UHD 620
Lenovo Ideapad 330S-14IKB
Intel Core i3-8130U
Lenovo IdeaPad 330S-14IKB 81F4018RGE
8GB
Intel-UHD 620
500GB WD, 120GB SSD (M.2 PCIE 2242)
Intel Core i3-8130U
8GB
Intel-UHD 620
type msinfo32 into start search
click it when it pops up
look under components>problem devices
then click file>export and save as .txt
No problem devices in this screenshot, so showing usb devices as an example of what it looks like
Or if it isn't showing under problem devices, highlight components and export as .txt
Or you can get it from device manager
    7 X64i5 84002x8gb 3200mhz
    7 X64
    i5 8400
    gigabyte b365m ds3h
    2x8gb 3200mhz
    various
    pure power 11 400w cm
    Coolermaster
    cryorig m9i
    7x64g54008gb ddr4 2400
    7x64
    g5400
    ga b365m ds3h
    8gb ddr4 2400
    xfx pro 450w
msinfo32 does not exist in that iso...
is this enough ?
lenovo 330s 14
windows 7
8 gb
    7 X64
    i5 8400
    gigabyte b365m ds3h
    2x8gb 3200mhz
    various
    Coolermaster
    cryorig m9i
    7x64
    g5400
    ga b365m ds3h
    8gb ddr4 2400
    xfx pro 450w
@davelon
1. Lenovo usually have a key ( often F6 ) which toggles the touchpad on and off. It has a little white square with a line throught it.
2. I have adjusted the win7 synaptics drivers by adding the line SYNA3255 next to every instance of SYNA2B2C in the original inf and ini files.
for example
[SynHidI2c.NTamd64.6.1]
%SynHidI2c.DeviceDesc% = SynHidI2c, ACPI\PNP0C50, PNP0C50
[B]
%SynHidI2c.DeviceDesc% = SynHidI2c, ACPI\SYNA3255[/B]
%SynHidI2c.DeviceDesc% = SynHidI2c, ACPI\SYNA2B2C
  %SynHidI2c.DeviceDesc% = SynHidI2c, ACPI\SYNA2B33
synaptics-3255
Unzip it and use dism++ to install. Then reboot and see the result.
View attachment Dism++10.1.1000.100.zip
    7 X64
    i5 8400
    gigabyte b365m ds3h
    2x8gb 3200mhz
    various
    Coolermaster
    cryorig m9i
    7x64
    g5400
    ga b365m ds3h
    8gb ddr4 2400
    xfx pro 450w
Amazing, but ho to use Dism++, to install drivers?
lenovo 330s 14
windows 7
8 gb
Extract the zip file.
run dism++ it and it says DRIVERS in the left pane.
Obviously click DRIVERS.
Then it says ADD
Obviously, click ADD
A browse window opens so you can browse to the folder of drivers.
1.
2.
3.
That's it.
    7 X64
    i5 8400
    gigabyte b365m ds3h
    2x8gb 3200mhz
    various
    Coolermaster
    cryorig m9i
    7x64
    g5400
    ga b365m ds3h
    8gb ddr4 2400
    xfx pro 450w
Adding the id's often works, but not always. The only way to find out is to try.
    7 X64
    i5 8400
    gigabyte b365m ds3h
    2x8gb 3200mhz
    various
    Coolermaster
    cryorig m9i
    7x64
    g5400
    ga b365m ds3h
    8gb ddr4 2400
    xfx pro 450w
Win 7 HP SP1 64-bit Vista HB SP2 32-bit Linux...Intel(R) Pentium(R) CPU P6200 @ 2.13GHz4.00 GBIntel(R) Graphics Media Accelerator HD
Fujitsu LIFEBOOK
Win 7 HP SP1 64-bit Vista HB SP2 32-bit Linux Mint 18.3
FUJITSU FJNBB06
4.00 GB
[1] Realtek High Definition Audio [2] Intel(R) Display Audio
TOSHIBA MK5076GSX
AVG FREE
amazing forum, amazing community and amazing help
is with great sadness that i can say it didn't work
tank you for everything, we tried
Dave
lenovo 330s 14
windows 7
8 gb
Hi Paul Black
you bat file is not working onto the iso that has been suggested, it keep asking for administrator privileges, even when given, even when it start from a cmd with administrator privileges
lenovo 330s 14
windows 7
8 gb
Hi davelon,
Your bat file is not working onto the iso that has been suggested, it keep asking for administrator privileges, even when given, even when it start from a cmd with administrator privileges.
Not quite sure what you mean by onto the iso!
Very strange, right-click the .bat file and select Run as administrator. This is only to produce the description of the problem device and the error code with the reason why it is a problem.
I hope this helps!
Fujitsu LIFEBOOK
FUJITSU FJNBB06
4.00 GB
TOSHIBA MK5076GSX
AVG FREE
i'm referring to the win 10 iso that SIW2 gave to me to boot up, for checking the device id it's very light and is not capable to run your bat file
lenovo 330s 14
windows 7
8 gb
Hi davelon,
I hope this helps!
I think he is trying to run it from booted PE. Possibly you have a privileges check in your batch? PE runs as system account therefore no administrator token.
    7 X64
    i5 8400
    gigabyte b365m ds3h
    2x8gb 3200mhz
    various
    Coolermaster
    cryorig m9i
    7x64
    g5400
    ga b365m ds3h
    8gb ddr4 2400
    xfx pro 450w
Hi SIW2,
I have the following [at the top of the code] as a Run as administrator [elevated command prompt] check . . .
OpenFiles > NUL 2>&1
If NOT %ERRORLEVEL% EQU 0 Goto :Not_Admin
Fujitsu LIFEBOOK
FUJITSU FJNBB06
4.00 GB
TOSHIBA MK5076GSX
AVG FREE
That will be the reason for the error message in PE. Also, I can't recall if I included msinfo32.exe in that 16299 pe build.
    7 X64
    i5 8400
    gigabyte b365m ds3h
    2x8gb 3200mhz
    various
    Coolermaster
    cryorig m9i
    7x64
    g5400
    ga b365m ds3h
    8gb ddr4 2400
    xfx pro 450w
there isn't
if you create another build with msinfo32.exe please let me know and i will do the test
lenovo 330s 14
windows 7
8 gb
And..., some news about it?
Windows 10 Pro x64i3 Kaby Lake-R4 GB + 16 OptaneIntal UHD 620 + Geforce MX130
Asus
i3 Kaby Lake-R
Asustek
4 GB + 16 Optane
1 TB
ESET
