Touchpad and USB does not work after fresh install
Is there anything showing under Details> Compatible IDs
found Compatible ID's under a different section.
I2C HID Device: "ACPI\ELAN469D" Compatible Id: "ACPI\PNP0C50"
[Human Interface Devices]
[HID-compliant touch pad]
[Details: Hardware Ids]
HID\VEN_ELAN&DEV_469D&Col02
HID\ELAN469D&Col02
HID\*ELAN469D&Col02
HID\VID_04F3&UP:000D_U:0005
HID_DEVICE_UP:000D_U:0005
HID_DEVICE
[Details: Compatible Ids:]
<none>
[Matching device Id]
[Configuration Id]
input.inf:HID_DEVICE_UP:000D_U:0005,HID_Raw_Inst.NT
[I2C HID Device]
[Details: Hardware Ids:]
ACPI\VEN_ELAN&DEV_469D
ACPI\ELAN469D
*ELAN469D
ACPI\PNP0C50
PNP0C50
[Inf name]
hidi2c.inf
[Driver version]
10.0.16299.15
[Configuration Id]
hidi2c.inf:ACPI\PNP0C50,hidi2c_Device.NT
[Driver stack]
\Driver\mshidkmdf
\Driver\hidi2c
\Driver\ACPI
[Microsoft Input Configuration Device]
HID\VEN_ELAN&DEV_469D&Col03
HID\ELAN469D&Col03
HID\*ELAN469D&Col03
HID\VID_04F3&UP:000D_U:000E
HID_DEVICE_UP:000D_U:000E
HID_DEVICE
<none>
[Mice and other pointing devices]
[HID-compliant-mouse]
<same as the Microsoft Input Configuration Device>
Lenovo Ideapad 330S-14IKB
Intel Core i3-8130U
Lenovo IdeaPad 330S-14IKB 81F4018RGE
8GB
Intel-UHD 620
500GB WD, 120GB SSD (M.2 PCIE 2242)
Intel Core i3-8130U
8GB
Intel-UHD 620
I ran the dpinst.exe as administrator and rebooted but nothing is different.
Is there something special I need to do? disable the existing HID devices first?
Btw, found an older Lenovo Yoga Win8 downgrading to Win7 with the same problem with touchpad with same (Compatible ID see red below): Downgrading from Win 8 and making I2C touchpad work with Windows 7 - Lenovo Community
01-21-2015 10:17 AM
Lenovo Yoga 3 Pro-1370, Intel Core M (CPU: 5Y70)
I have downgraded Lenovo Yoga 3 Pro-1370 to Windows 7-64 and its touchpad (Synaptics) is not detected by Windows at all (and not shown in Device Manager). As far as I understand, the touchpad is connected via I2C interface (not USB or PS2). I2C is handled by Windows 8 at a systemic level and very differently from Windows 7.
Lenovo does not support Windows 7 on Yoga 3 and does not provide Windows 7 drivers.
I tried different Win7 Synaptics drivers from other Lenovo models as well as generic drivers from Synaptics. No success.
What is the likelihood of making the touchpad to work with Windows 7? Will OEM drivers from other manufactures possibly work?
For Windows 8, the Yoga 3 chipset includes ‘Intel Serial I/O Driver’ which (I guess) takes care of I2C.
In Windows 8 Device Manager, there are 3 devices related to the touchpad
Touchpad itself
HID\VEN_SYNA&DEV_2B22&Col01
HID\SYNA2B22&Col01
HID\*SYNA2B22&Col01
HID_DEVICE_SYSTEM_MOUSE
HID_DEVICE_UP:0001_U:0002
HID_DEVICE
Driver: Synaptics
Intel(R) Serial IO I2C Host Controller - 9CE1
Driver: 'iaLPSS_I2C.sys' (Intel)
ACPI\VEN_INT&DEV_3432&REV_0003
ACPI\INT3432
*INT3432
Enumerator: ACPI
oem7.inf
I2C HID Device (on Intel(R) Serial IO I2C Host Controller - 9CE1)
ACPI\VEN_SYNA&DEV_2B22
ACPI\SYNA2B22
*SYNA2B22
Compatible Ids: ACPI\PNP0C50
HID\SYNA2B22&Col01\5&f4a3470&0&0000
HID\SYNA2B22&Col02\5&f4a3470&0&0001
Parent: ACPI\INT3432\3&11583659&0
Driver: Microsoft
Enumerator: ACPI
hidi2c.inf
Intel Core i3-8130U
8GB
Intel-UHD 620
Intel Core i3-8130U
8GB
Intel-UHD 620
Where'd it come from? Know how I can put my WiFi drivers on it (in it)?
Yes.
1.Copy boot.wim from your usb stick sources folder to your hard drive.
2.Mount boot.wim using dism++.
3.Add the drivers.
4.Save the image.
5.Unmount the image.
Copy the updated boot.wim into the sources folder on your usb stick.
You are best using the win10 wifi drivers from your manufacturers website.
screenshots for using dism++
In addition, before saving the image ( step 4 above) I suggest:
Copy the pecmd.ini file from this zip View attachment SYSTEM32-new-pecmd-ini.zip into the mounted boot.wim Windows\System32 to replace the existing one.
Then place the two files from this zip View attachment Root-of-USB-stick.zip on the root of the usb stick.
Create a folder on the root of your usb stick called Uprograms.
MOVE these folders from your mounted boot.wim Program Files to Uprograms folder on the usb stick.
MOVE this folder from the mounted boot.wim Program Files (x86) to Uprograms folder on your usb stick
Now save the Image, then unmount the image.
    7 X64
    i5 8400
    gigabyte b365m ds3h
    2x8gb 3200mhz
    various
    pure power 11 400w cm
    Coolermaster
    cryorig m9i
    7x64
    g5400
    ga b365m ds3h
    8gb ddr4 2400
    xfx pro 450w
SIW2 any idea about the touchpad driver I commented on above?
Intel Core i3-8130U
8GB
Intel-UHD 620
Your usb stick layout will look something like this:
Inside the Uprograms folder will be the folders you just moved ( similar to this)
    7 X64
    i5 8400
    gigabyte b365m ds3h
    2x8gb 3200mhz
    various
    Coolermaster
    cryorig m9i
    7x64
    g5400
    ga b365m ds3h
    8gb ddr4 2400
    xfx pro 450w
You could try running the setup.exe instead of dpinst. And/or you could try uninstalling the current drivers from device manager before running setup.exe. And/or you can try installing the drivers using dism++.
    7 X64
    i5 8400
    gigabyte b365m ds3h
    2x8gb 3200mhz
    various
    Coolermaster
    cryorig m9i
    7x64
    g5400
    ga b365m ds3h
    8gb ddr4 2400
    xfx pro 450w
Yes.
1.Copy boot.wim...
...Now save the Image, then unmount the image.
Thanks for that. I did it all and the WiFi driver loads without error in the device manager.
And it sees my router but when I type in my password and click connect it doesn't do anything.
Is some part of the WLAN sofware missing from this live-USB?
Intel Core i3-8130U
8GB
Intel-UHD 620
I have a lenovo 330s, 14.. with windows 7, I have installed every driver missing with the help of snappy driver installer origin, but I'm unable to have the touch-pad working, I have tried and read everything without success.
I have only one driver that is missing because it's not recognized ans seem ties to the lack of support of tpm 2.0
any help ?
Dave
lenovo 330s 14
windows 7
i5 8250u (real quadcore 8 threads)
8 gb
crucial 1 tb nvme qlc
    7 X64
    i5 8400
    gigabyte b365m ds3h
    2x8gb 3200mhz
    various
    Coolermaster
    cryorig m9i
    7x64
    g5400
    ga b365m ds3h
    8gb ddr4 2400
    xfx pro 450w
Or disable tpm in bios. It is for bitlocker, which most people don't use.
    7 X64
    i5 8400
    gigabyte b365m ds3h
    2x8gb 3200mhz
    various
    Coolermaster
    cryorig m9i
    7x64
    g5400
    ga b365m ds3h
    8gb ddr4 2400
    xfx pro 450w
TPM fixed with the hot fix, but touchpad still dead, and no set up into the bios whatsoever
mmmhhh...
lenovo 330s 14
windows 7
8 gb
    7 X64
    i5 8400
    gigabyte b365m ds3h
    2x8gb 3200mhz
    various
    Coolermaster
    cryorig m9i
    7x64
    g5400
    ga b365m ds3h
    8gb ddr4 2400
    xfx pro 450w
If it doesn't work, get your device id and add it into the ETD.inf and the ETDHCF.inf under the
[ELANMfg.NTamd64] sections
    7 X64
    i5 8400
    gigabyte b365m ds3h
    2x8gb 3200mhz
    various
    Coolermaster
    cryorig m9i
    7x64
    g5400
    ga b365m ds3h
    8gb ddr4 2400
    xfx pro 450w
lenovo 330s 14
windows 7
8 gb
i mean, they aren't windows 7 drivers , lenovo never made them
lenovo 330s 14
windows 7
8 gb
I think he's explaining how you can try to make the V330 Win7 driver work on your 330S notebook.
Make sure you're running the latest Lenovo BIOS release.
Intel Core i3-8130U
8GB
Intel-UHD 620
Correct. Officially there are no win7 drivers for HD630, but the modified inf files work, officially there are no win 7 usb3 drivers for x570 mobo/amd3000 cpu, but the modded inf files work, etc, etc.
no guarantees, but it is worth a try.
    7 X64
    i5 8400
    gigabyte b365m ds3h
    2x8gb 3200mhz
    various
    Coolermaster
    cryorig m9i
    7x64
    g5400
    ga b365m ds3h
    8gb ddr4 2400
    xfx pro 450w
