USB Driver - General Fix for Problems
General Fix for USB Driver Problems
I recommend using a wired mouse and keyboard, removing all USB devices and in the section where it says Uninstall all the faded entries. take that as reading uninstall everything USB, if you cannot get hold of a wired mouse then you will have to follow the tutorial as written.
After going through this tutorial You may need to reinstall some USB device drivers!!
After a USB device is installed and then removed Windows hides the driver, this first part makes all hidden drivers visible.
1. Unplug all USB devices except mouse and keyboard.
2. Click on Start orb, :orb: Type Advanced System settings in the search box and Click on View Advanced System Settings to go there.
3. Click on Advanced tab, Click on Environment Variables.
4. Under the window "System variables" Click on New.
5. Type devmgr_show_nonpresent_devices as the variable name and type 1 as the value.
6. Click OK 3 times to close the windows.
7. Click on Start orb, :orb: Type Device Manager in the search box and Click on Device Manager in the list to go there.
8. Click on View, then Show hidden devices.
9. You will now notice that you have a list of USB devices and that some lines appear to be faded. Uninstall all the faded entries.
The INFCACHE.1 file is used to store information about USB drivers, the information in this file may have become corrupted and may cause windows to load the wrong driver or cause a driver not found message to be generated.
Deleting this file will force windows to generate a new INFCACHE.1 file.
1. Right Click on Start orb :orb: and Click on Open Windows Explorer.
2. Select Computer in the navigation pane, and search for INFCACHE.1
3. Right Click on the file INFCACHE.1 (if you have more instances of Windows installed only do this for INFCACHE.1 C:\Windows\System32\Driver Store)
4. Click on Properties, Click on Security tab, Click on Edit, Click on Add.
5. Type Administrators in the window with the blinking cursor, Click OK.
6. Delete the INFCACHE.1 file.
7. Connect a USB device, but not the one you were having trouble with this will make a new INFCACHE.1
8. New Start the PC and try your device again.
NOTE... It may, in a few cases be necessary to go through this Tutorial two or even three times to get this to work.
where do i find the INFCACHE.1,,,, what do you mean by uninstall? you mean that i will uninstall all the USB ports on my LAptop then the INFCACHE.1 will appear? sorry im just a newbie for this problem please help me :(
INFCACHE.1 is located in C:\Windows\System32\DriverStore
The rest of the instructions are clearly listed in the original post by pooch if you scroll back up.
Less is more
Core i7 2600k (4.6GHz)
ASUS P8Z68 Deluxe (3603)
16GB G.SKILL Ares 1600MHz
MSI R6970 Lightning
Asus Xonar Essence ST (UNi drivers 1.41)
Samsung P2570, CrossOver 27Q LED-P
1920*1080, 2560*1440
256GB OCZ Vector, 2x Hitachi 4TB (7K4000), Hitachi 3TB (7K3000 & 5K3000)
Seasonic X750
Lian-Li PC-P80N
NZXT HAVIK 140 (2x GELID Wing12PL Push/Pull)
CM Storm Trigger (Brown Switch)
Logitech G400
55Mbps/10Mbps
Speakers - Klipsch ProMedia 2.1
Headphones - Sennheiser HD595
Router - ASUS RT-N66U
Webcam - Logitech C910
similar problem but pooch's solution won't hold
Hey all,
So I'm having a similar problem, I think, but the general solutions doesn't totally work.
I have at least 4 different USB controllers (one multi-card reader in front, another 2-port in front with the headphone/mic jacks, two in back, and a 3.0 in back)... but I'm not perfectly sure how to identify any of these in the Device Manager.
Nonetheless, Pooch's solution works for me, but only for the reboot immediately following the procedure. On the next reboot, all but one of my USB controllers won't start (I get the code 10 in the device manager). But, if I go into the Device manager, and 'disable' each controller, then 'enable' each controller, I can get all the ports to work. Until the next time I reboot the system. I tried the pooch-solution three different times, all with the same outcome, one good reboot, then back to 'code 10' on all but one bank of ports.
I'm doing my best to avoid reinstalling windows, and since eventually I can get all the ports to work, I feel like it's just a software problem. I'd prefer not to have to access the device manager every morning when I turn the machine on, so I'm hoping for some sort of solution.
This basically started happening without any major hardware changes. I did have a USB flash drive that was causing my problems, and I started troubleshooting that, and I'm guessing maybe some 1 got changed to a 0 in the process.
Any thoughts?
--Dave
Just a quick question regarding the above tutorial:
I am having intermittent success in getting my system to recognise a Freecom external USB HDD.
Freecom themselves have directed me to the infcache.1 renaming process as described above, but their version said to delete only shaded entries in the USB controllers list. Also I could not rename infcache.1 even though I set full permissions, and ultimately changed ownership of it. I even tried to move it out of the DriverStore folder - which I could do, but Windows did not rebuild it and it would not let me put the old one back! I ended up using System Restore to revert to the setting from 24 hours previous. So I am back where I started.
If I delete ALL listing under Device Manager > USB controllers, as directed above, will that impact on the fact that both my keyboard and mouse are connected via USB? My mobo does not have PS2 connectivity.
Self built
Windows 7 Professional 64 bit
Intel i7 3820 3.6Ghz 10mb quad core
ASUS P9x79 Pro
16 GB Corasir Dominator 1600 mHz (2 x 8 GB)
ASUS Radeon HD7870 2GB Direct CUII
Onboard - Realtek
2 x AOC F22
1 x 2TB Seagate Barracuda 7200 rpm
1 x 500 GB Hitachi
1 x 400 GB Freecom USB 2.0 External
ADATA 800W PSU
Antec Eleven Hundred
Intel RTS2011LC Liquid Cooling System
On the step where we have to open windows explorer, and i type in INFCACHE.1 nothing comes up.
Hello Wally, and welcome to Seven Forums. :)
Did you select Computer in the navigation pane first to search for INFCACHE.1 in Computer?
Yes I did. I figured it out though. I just did a system restore to two days ago and started the tutorial over. So far everything's fine. Just one question, when it says connect usb device, does that mean just insert the usb cord.? Or should I insert the cord and my phone.?
Good news. Yes, it means to connect both to connect the device completely. :)
I kept my phone plugged in while it was restarting. When the computer started back up, it charged, but that only lasted for a few seconds. Anyone know why.?
For anyone who cannot delete the INFCACHE.1 file, there's a solution:
After creating "Administrators" in Step 5, please check all the box under "Allow" (such as totally control, edit, read&execute, etc -> I'm using a Chinese OS so the wordings may not be exactly the same ;)
That should fix and can delete the file now
Windows 7 Professional x32
THE BEST!!!!
Pooch, this bsod was driving me CRAZY!!! The usb mouse would disconnect every once in a while and unplugging/plugging back in solved the issue.
Then all of a sudden, after about 3 s/w installs and MS Updates, the fe error.
Thought it was the mobo. Then h/w. Uninstalled the new s/w. Nope.
About to go out and buy new mobo, figuring it was the mouse/keyboard inputs.
Found this tutorial. Holy Mackerel!!! The number of greyed out usbs was over 30.
The issue of Admin addition not working is because you have to add Rights to that user; are not automatically granted.
Thank you pooch, very much.
Win 7 Ultimate 64
AMD Phenom II 64 940
8 GB
Envision 19
hi pooch,
Help please,
I have an Imation Usb Flash disk 4GB nano pro,
everytime I plug in to my Toshiba Laptop A300 using Windows 7
it says windows update cannot find the driver ,
so it say usb device not recognized and I cant see it in my Devices with removable storage.
When i go to device manager, i can see the unknown device as nano pro
but no driver installed, it has an yellow exclamation mark. tried update driver but failed because Windows 7 cannot find it online.
When i run Ubuntu OS on the same laptop,
usb imation is working so i guess theres a problem only with Windows 7 driver or Windows 7 OS .
I followed your instruction here but still it doesnt work because it doesnt have a driver,
Also, i tried a different brand usb flash disk and its working, only this Imation brand is not.
Thanks a lot
win 7 ultimate
Mmmm none of this works for me i have 2 different systems same hardware different mother boards both asus
1 a p5VD1_X(X-XP3) and a P5bw-LA (x-VISTA) both newdrives to windows 7 ultimate everthing is ok with the P5VD but none of the usb ports internal and external work on the P5BW if i put the vista drive back in all works well so problem is not hardware but is windows seven dose not like my board althoug seven adviser said all was ok.
All usb ports are live but do not read or write they show in device manager
I have done all as above but does not work so no need to go back over that!
ran driver wizard and all drivers are upto date.
When i compare device manager USB's they are titled different?
Anyone anyfurther Ideas
self builds
7 ultimate 32bit 4off
3.6ht 3.9ht intel 755
asus p5vd1-x asus p5bw-la
pc3200 3gig pc 6400 2 gig
nvidea 7300gt nvidea 9500gt
trust 5.1 surround
relisys 21" flat screen hd 3d
seagate300gbx2
x power 750watt
compaq presario vento ak
intel fans
For those asking about how to delete the infcache.1 file, I deduced after adding administrators it would be necessary to check the boxes regarding permissions.
Homebrew
Window 7 Pro 64 bit
Intel Core 2 Duo E6700
EVGA nForce 680i SLI 122-CK-NF68
8 gb G Skill DDR 2 PC2-6400
Radeon x550
My system has been freezing a lot so this looked like a good option. I do not have a wired mouse so had to use a USB version. Have restarted the computer but none of the USB ports seem to be active; that is to say, none of the devices respond, including the mouse and keyboard! Is there a way that I can activate the USB ports?
CANCEL - sorry, after rebooting (a couple of times) the usbs became active!
Windows 7 home premium 32bit
USB Driver Problems
I am having trouble with my laptop (HP Compaq 6715b) USB ports as I have followed each step by pooch about three to four times. I have searched Google and Youtube but no luck except this thread.
Before having this problem, my USB ports were working fine about five (5) to eight (8) days ago. These ports cannot be dead as I have tested an old USB stick (to create the new INFCACHE.1 file when following pooch's steps) and my USB mouse and keyboard. Both work in all four (4) USB ports and no errors.
Once I put in the devices that I need for data and transferring data to is - Seagate External HDD which is brand new bought just before Christmas 2012, Samsung smartphone and USB stick. All these devices give me the balloon error "USB Device Not Regonized". Strangely enough the USB stick that I inserted to refresh the INFCACHE.1 file by following all steps given by pooch works.
Also, these devices that I am trying to get to work, all of these devices work on my PS3 but not on my HP Compaq 6715b laptop.
If anyone can please help me that would be much appreciated as I need to get data from these devices and also copy data onto other devices for back up.
Thank you!
Mexako
Windows 7 Ulimate x32
I have solved my USB copy problems on my Asus P8P67 Pro motherboard by updating the BIOS to the latest version.
Windows 7 x64
I get stuck at following poing:
After clicking on OK as you mentioned in point 5 following widows appears.
it says:
Can not find an object named "Administrators". Check the accuracy of the selected object types and location, and make sure you typed the object name correctly, or remove this object from the selection.
( ) Correct information object and search again
( ) Remove "Administrators" selection
What do I have to do in this window?
Thank you for your help!
Hannes
HP desktop
Windows 7 Home Permium, Service Pack 1, 64bit
Thank you SOOO MUCH!
I've been trying to get my wireless mouse to work for almost a week now. This tutorial finally fixed it along with a few other devices that were giving me issues on the USB front. I can't say enough how much this helps me out, I hate using a touch pad and it's been driving me crazy!
Windows 7 Home Premium
Intel
United States
+10
I Googled for days attempting to fix my wireless mouse stuttering. This fix made a 99% improvement.
Custom, Dell and Lenono LT's
Win8/8.1,Win7-U64, Vista U64, uncounted Linux distor's
AMD and Intell, 9590, 8350, i5 3570k
CFVFZ, GA990FXA, Z77e-itx
Corsair G Skill
Crossfired Sapphire HD 7950 Vapor-X, ASUS R9 280X TOP
Realtek ALC889
ViewSonic VX2770SMH 27" / ViewSonic VX2433 LCD 24"
1080i HD
Samsung SSD 840 Pro
OCZ Agility 3's
OCZ Vector's
WD's Blue, red, green, Velociraptors
Seagate USB3 & Hybrid's
ASUS Blu-Ray
ASUS DVD
Corsair AX1200i, Seasonice 850 Gold
Cooler Master HAF 922 & HAF 932, Lian Li Train case.
Air, Glacer 240L expanded, custom EK loop with duel D5's
Microsoft SideWinder X4 USB Keyboard / Logitech 250 PS2
Logitech G500 / MS wireless 5000
Best of 5ms / 75+ dn / 12+ up More or less.
MS esentials-MalwareBytes
Firefox Chromebook
