So here's the first details as per the rules... The rest of the problem is at the bottom.
Wireless Connection issue
ISP- Skybroadband (Outside US)
DSL
Modem-Cisco 2100
Router-Cisco E2500
Just removed anti-virus (formerly Avast!)
ipconfig /all result:
Windows IP Configuration
Host Name . . . . . . . . . . . . : jmariano-PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Wireless LAN adapter Wireless Network Connection 2:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Microsoft Virtual WiFi Miniport Adapter
Physical Address. . . . . . . . . : 72-F0-6D-78-87-65
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Ethernet adapter Bluetooth Network Connection:
Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network)
Physical Address. . . . . . . . . : 1C-4B-D6-19-82-0F
Ethernet adapter Local Area Connection:
Description . . . . . . . . . . . : Atheros AR8131 PCI-E Gigabit Ethernet Controller (NDIS 6.20)
Physical Address. . . . . . . . . : 20-CF-30-12-DD-3D
Wireless LAN adapter Wireless Network Connection:
Description . . . . . . . . . . . : Atheros AR9285 Wireless Network Adapter
Physical Address. . . . . . . . . : 74-F0-6D-78-87-65
Tunnel adapter Local Area Connection* 14:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter isatap.{A64AD6BE-A799-4B87-9E3D-348EF42A087F}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Tunnel adapter isatap.{B0A06AE2-9B93-449A-9739-135FAD8C5E5E}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #3
Tunnel adapter isatap.{229B82A1-32FB-49B4-906D-B19B3650E26C}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #4
Tunnel adapter isatap.{92B00E7C-15EE-42FC-9AB5-9AF21DD4217D}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #5
I'd download the Wi-fi inspector but I can't since my laptop can't connect to the network and I'm only using a tablet.
I'm using an asus U35jc running on windows 7 and since letting it hibernate with open tabs (something I do all the time) yesterday, I found that it's no longer connected to the network (wifi) after turning it on again. I have tried rebooting my laptop countless of times, tried rebooting BOTH the router and the modem multiple times but to no avail. All the other devices at home can connect just fine. My laptop would just go from asking the password and then proceed to troubleshooting mode after I enter the password. I've had the same problem before but it usually gets resolved after some rebooting on the network. Also, I can connect on my neighbor's network just fine but since removing his network from my list, I've been having the same problem with his network. Now I'm just stumped. Any help?
Things I've tried:
-Restarting the laptop
-Restarting the laptop, the modem, the router
-Restarting the modem and the router
-Pushed the restart button on the router for 30 secs.
-Removed my wireless network on windows, rebooted, enabled
-Uninstalled avast antivirus software
-Internet connection works fine with the Ethernet cable plugged
Command prompt <ipconfig /release> and </renew> gives me this message:
>No operation can be performed on Wireless Network Connection 2 while it has its media disconnected.
>No operation can be performed on Bluetooth Network Connection while it has its media disconnected.
>No operation can be performed on Local Area Connection while it has its media disconnected.
>No operation can be performed on Wireless Network Connection while it has its media disconnected.
DSL
Modem-Cisco 2100
Router-Cisco E2500
Things I've tried:
- Computer type
- Laptop
- Asus U35JC
- Windows 7 Home Premium 64bit
- Intel Core i3
- Motherboard
- M370
- 2.40GHz
- Antivirus
- None
- Browser
- Chrome
