Shut Down - Enable or Disable Shut Down without Logging On
    How to Enable or Disable Shut Down without Having to Log On
    This will show you how to enable or disable all users to be able to shut down the computer without having to log on in Windows 7. This will add or remove the red shut down menu box in all Log on and Switch user screens.
    You will need to be logged in as an administrator to be able to do this tutorial.
    EXAMPLE: Log On Screen with Shut Down Enabled and Disabled
    OPTION ONE
    Using a REG File Download
    1. To Enable Shut Down without Having to Log On
    Enable_Shutdown_without_Logon.reg
    B) Go to step 3.
    2. To Disable Shut Down without Having to Log On
    Disable_Shutdown_without_Logon.reg
    4. Right click on the downloaded .reg file, and click on Merge.
    5. Click on Run, Yes (UAC), Yes, and OK when prompted.
    6. When done, you can delete the downloaded .reg file if you like.
    OPTION TWO
    Manually in Registry Editor
    1. Open the Start Menu, then type regedit in the search box and press Enter.
    3. In regedit, navigate to the location below. (see screenshots below)
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System
    4. In the right pane, right click on shutdownwithoutlogon and click on Modify. (see screenshot above)
    5. To Disable Shut Down without Having to Log On
    A) Type 0 (number zero), and click on OK. (see screeshot below)
    B) Go to step 7.
    6. To Enable Shut Down without Having to Log On
    A) Type 1, and click on OK. (see screeshot above)
    7. Close regedit.
    OPTION THREE
    Through Local Security Policy
    1. Open the Local Security Policy editor.
    2. In the left pane, expand Local Policies, and click on Security Options. (see screenshot below)
    3. In the right pane, right click on Shutdown: Allow system to be shut down without having to log on and click on Properties. (see screenshot above)
    4. To Disable Shut Down without Having to Log On
    A) Select (dot) Disabled, and click on OK. (see screeshot below)
    B) Go to step 6.
    5. To Enable Shut Down without Having to Log On
    A) Select (dot) Enabled, and click on OK. (see screeshot above)
    6. Close the Local Security Policy window.
  1. Posts : 350
    NICe Tutorial
  2. Posts : 5
    xp and seven
    hey, is there any way to change the default button behaviour? ( i need to set it to sleep by default)
  3. Posts : 72,091
    Hello Webtax,
    If you mean the red shut down button in the example screenshot in the tutorial, then you would need to click on the arrow and select sleep instead.
    If you mean in Start Menu power button, then see: How to Change the Default Windows 7 Start Menu Power Button Action
    Hope this helps, :)
  4. Posts : 20
    Windows 7 Home Premium 64-bit, Windows 8 Pro 64-bit
    The gift that still keeps on giving :) Thank you Brink, this is exactly what I was looking for :)
