Hard Disk Partition Letter Missing in Windows 7 - Fix
    How to Fix Missing Vista Hard Disk Partition Letter in Windows 7
    This will show you how to fix the missing already installed Windows Vista hard disk partition in Windows 7 when you have just installed Windows 7 from boot to dual or multi boot with Vista.
    This will also work for a missing XP hard drive partition in Windows 7 as well.
       Tip
    If you install Windows 7 from within Vista to the other partition or drive instead, then Vista should show up in Windows 7 then. However, installing Windows 7 from within Vista instead of at boot may not always install properly if something in Vista interferes during installation.
    EXAMPLE: Missing Vista Hard Disk Partition Letter in Windows 7
    NOTE: The left screenshot is in the Computer window, and the right screenshot is in Disk Management.
    Here's How:
    1. Open the Control Panel (All Items view), and click on the Administrative Tools icon, then close the Control Panel window.
    2. Click on Computer Management in Administrative Tools.
    3. If prompted by UAC, click on Yes. Close the Administrative Tools window.
    4. In the left pane under Storage, click on Disk Management. (See screenshot below step 5)
    5. In the right pane, right click on the Vista hard disk partition that is missing it's drive letter, then click on Change Drive Letter and Paths. (See screenshot below)
    6. Click on the Add button. (See screenshot below)
    7. Select (dot) Assign the following drive letter, then select a drive letter you want to have assigned to the Vista disk partition and click on OK. (See screenshot below)
    8. The Vista Hard Disk Partition will now show up in Windows 7. (See screenshots below)
  1. Posts : 6
    "Change Drive Letter and Paths" is not available
    What if the option "Change Drive Letter and Paths" is greyed out?
  2. Posts : 72,063
    Hello Longnh, and welcome to Seven Forums.
    Could you post a screenshot of your Disk Management showing all of your drives layout? :)
  3. Posts : 6
    Hey Brink, thanks for your quick reply.
    I'm using dual XP and Windows 7. That partition (F:) didn't show up in Windows 7 though I can still see it in Disk Management (the only information is total size, there's no label, letter, free space, used space). When I right-clicked, "Format" was the only option available in context menu (Disk Management). Everything's normal in XP, I mean I can read/write to that partition if I boot into XP. It's so weird.
    After I formatted that partition, it works well now (so I cannot take any screenshot). I can see it in both XP and Windows 7 (but my data was gone, of course). Basically my problem was solved, but I'm still curious about this error.
  4. Posts : 72,063
    Longnh,
    I'm not certain what was the issue, but I'm happy to hear that you got it sorted. :)
  5. Posts : 6
    Windows 7 Ultimate X64 SP1
    Hello Brink..
    I have same problem like longnh have.. this my screenshot
    i have important file in my 2 partition.. please help me , to make 7 assign this partition without format it
    Thanks in Advance
    Bajol
  6. Posts : 72,063
    Hello Bajol,
    Do you have access to them to be able to copy the files to another location, then format them to get a drive letter and copy the files back?
  7. Posts : 6
    Brink said:
    Hello Bajol,
    No I can't acces it..
    In this case, i'm login as administrator. But I'm still can't acces both of them.
    My only way is acces the drive from XP and backup the files from there.
    i have formatted HDD through 7 disk management and 7 can recognize now
    thanks for the advice
    Bajol
  8. Posts : 72,063
    You're most welcome Bajol. I'm happy to hear that you got it sorted. :)
  9. Posts : 2
    Brink:
    I am having the same problem. When my XP died I bought a HP running Windows 7 Home Premium 64. While most of the files I wanted are backed up to a portable hard drive, I thought the easiest way to move my files was to remove the drive from the old computer and put it in the new and drag and drop the files where I wanted on the new one. I then planed to keep the drive in for storage and backup.
    (I was not planning to duel boot to XP as I understand that windows checks and does not run on different computer, but if it is possible I would be interested in doing so)
    I have followed the steps listed to add a hard drive. I have scanned for changes. I have uninstalled and reinstalled the drive in Device Manager. I have changed folder options to show hidden files.
    I do not want to reformat the drive at least until I transfer some files off it.
    Any help you or other forum members can give will be greatly appreciated.
    Thank you very much.
    Ben
    Attached Thumbnails Attached Thumbnails Hard Disk Partition Letter Missing in Windows 7 - Fix-harddriveproblem.jpg   Hard Disk Partition Letter Missing in Windows 7 - Fix-harddriveproblem1.jpg
