Windows 7: Realtek HD Audio No Rear Sound
12 Jun 2009   #31
shaheer92
I use iTunes, and it worked fine before I installed windows 7. I used the same speakers with Realtek AC97 audio on my old motherboard, and it played audio perfectly from all the four speakers in iTunes, VLC, anything.
I'm installing AC3 Audio filter now. I hope it solves the problem. Thanks. :)
12 Jun 2009   #32
Dwarf
Windows 8.1 Pro RTM x64
Have you checked this option (highlighted) in the Realtek HD Audio Manager?
12 Jun 2009   #33
shaheer92
I've checked it out, but the audio that comes out of my rear speakers is...WEIRD. as if like its being played in a bathtub or something, with lots of reverb and voice cancellation.
12 Jun 2009   #34
Dwarf
Check these options as well.
12 Jun 2009   #35
shaheer92
They're already to none
12 Jun 2009   #36
jfar
Vista Ult64, Win7600
Hi, just try this, in Device Manager select the Sound, Video and game controller
And then whatever sound device you are using, right click on it and
Uninstall it, log off and then log back on, go back to Device Manager and at the top of the page click the Scan for hardware changes, and let windows reinstall your Sound
Controller. And we will see what happens.
12 Jun 2009   #37
shaheer92
Let me try this, then i'll tell you how did it go.
12 Jun 2009   #38
shaheer92
Btw, thanks a lot to ALL of you who've been trying to help. =)
I appreciate your effort.
12 Jun 2009   #39
shaheer92
Ok, Windows installed the driver, but its own MICROSOFT one, not Realtek. In the speaker configuration, there's no option for Quadraphonic and 5.1 Surround, only stereo.
[IMG]file:///C:/Users/ESS/AppData/Local/Temp/moz-screenshot.jpg[/IMG]
12 Jun 2009   #40
jfar
Ok so that didn't work, but it was worth a try, so put back on the Realtek drivers, by the way have you got SoundMax installed. also can you upload a picture of the Device Managers page,
with the Sound controller part open, as in my picture, Thanks.
Realtek ALC889 audio, audio fine on S/PDIF, nothing from rear output
I'm having a strange problem in my HTPC. Audio is coming perfectly fine out from the S/PDIF coaxial output, and it's normally connected only that way to the receiver, but now for other reasons I also need to connect it using a 3.5 mm to a small mixer. So in the sound manager I changed the output to...
Realtek HDMI+NVIDIA = no sound+frezze screen using pc rear audio jack
Hi every one i am new at this i might carry on please forgive me if that happens. i am having this Realtek HDMI+NVIDIA =No Sound issue + if i connect back to my rear audio jack with my speakers its fine to listen music but it freeze the screen during game play and gives out a loud buzz sound than...
Realtek HD Audio Manager ''Mute Rear Speakers'' HELP
Hey, For quite a while now i've been using a pair of USB Speakers. I had it set so my games came out my speakers and my Team speak Voice chat came through my headset. I recently decided to swap back to my Creative speakers, but now i have an issue. When i plug my speakers and headphones in...
Realtek HD Audio Non Working Rear Speakers
Hello Everyone , I recently searching in forums to get solved my problem , but no one fix that issue . I Read many threads so i need the fix because i'm sick to see another posts from fools that they don't know anything about software's or hardware's. So My Problem Is : Yesterday i format...
Realtek AC'97, No rear sound
Hi all, my problem is as follows: Currently running Windows 7 Professional 64, with an Asus A8N SLI Premium, which features the Realtek ALC850 (AC'97) audio chipset. Back when I had XP Pro, the 5.1 speakers I have worked fine. After upgrading, the rear speakers refuse to work. Checking the...
