Realtek HD Audio No Rear Sound
From Soundmax do you mean the speakers? If that, then no...I don't have those speakers.
I've installed Realtek again.
Windows 7Intel Core 2 Duo E7400 2.80 Ghz1GBNvidia GeForce 9500GT
Asus P5SD2-VM
1GB
Onboard
LG Flatron L1510M
1024 x 768
Western Digital 160GB 7200RPM
400W
1Mbps
You might need to enable Dolby Prologic in order to get 2 channel audio to make use of the surround speakers.
Try right-clicking on your volume icon and selecting playback devices. Highlight speakers and click on properties. From there, open the Dolby tab and check Dolby Prologic IIx. Clicking the box beside it will bring up the width and depth adjustments.
Windows 7 RCIntel Q6600 @3.52ghz (440x8)4 GB G-SkillSaphire Radeon HD4870 1GB
Windows 7 RC
Gigabyte EP45-DS3R
4 GB G-Skill
Onboard
Acer 22" LCD
Samsung Spinpoint F1 750GB
OCZ 750 watt
Arctic Cooling Freezer 7 Pro
I don't have a Dolby Tab.
The thing is, my speakers are 4.1 surround, not 5.1. But the SPEAKER fill doesn't work when I select the Quadraphonic Speaker option, I have to select 5.1.
Asus P5SD2-VM
1GB
Onboard
LG Flatron L1510M
1024 x 768
400W
1Mbps
I had exactly the same problem with my sound (Win7 RC 64-bit, 4.1 Speaker, Realtek AC 97). I tried the also the "Speaker Fill", but first I didn't hear anything. I skipped through the song, only my rear speakers active (front speakers were muted). And one part I did hear something, but it was very low. Next I checked "Loudness Equalization" and had normal sound! :)
Windows 7 RC (64-bit)
Message to thread starter: were you able to fix the problem? Coz I had a similar problem with you, just that my MONITOR sound didn't work.. and the headset and mic and speakers were all messed up.. lol. The only stable thing was the speakers..
So I was reading and everything didn't work out for me (although when I came here, I alr installed the newest Realtek driver from the site the realtek site, anyway..) so I tried experimenting..
And now, my speakers, mic + headset, and monitor sound all works simultaneously.. ^^~
If you haven't solved your problem, I will try to help.. coz my rear panel also works..
Windows 7Intel(R) Pentium(R) 4 CPU1 GbNVidia 7300 SE/7200 GS
Intel(R)
Intel
1 Gb
Philips 170B6CB
hey chiichan!
Sorry for replying so late. I read your post on the thread.
No, my problem is still not solved. I'd be glad if you can help me with the audio!
Asus P5SD2-VM
1GB
Onboard
LG Flatron L1510M
1024 x 768
400W
1Mbps
No / poor quality Rear Sound
I resolved this issue by downloading the latest drivers from Realtek http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=24&PFid=24&Level=4&Conn=3&DownTypeID=3&GetDown=false
Having installed the latest drivers I then launched the Realtek HD Audio Manager.
Changed speaker configuration to Quadraphonic (check both Full - range speaker boxes are ticked)
Then Select Sound effects tab. I have found that by selecting the environment "room" it has resolved the problem on my PC.
(With some of the sound effect options I still get no rear sound)
I realize the last entry in this thread has already been a while ago. However, I have been able to solve my problem, partly thanks to this thread.
I also want two pairs of speakers getting delivered the same signal from one soundcard.
Under WinXP, I used to have a Creative Labs Soundblaster Live! where I just had to activate "Quadrophonics" in the included software.
However, it wasn's that simple with the Realtek onboard sound adapter.
First, I downloaded the Realtek HD Audio-Manager on this German site: Realtek HD Audio-Treiber Download - ComputerBase
I installed it, but the start menu was missing. I found the necessary .exe in C:\Programme\Realtek\Audio\HDA\RAVCpl64.exe
The Audio Manager opened and I clicked numerous times here and there, even in the "Erweiterte Geräteeinstellungen" [Advanced Settings] in the upper right corner.
While testing some settings, I found out, what Realteks idea was:
Having another stereo jack at the FRONT of the computer case.
Luckily, my case has one. I plugged the second pair of speakers to the front panel and instantly had, what I wanted: Twice the identical stereo signal.
The solution is to attach a second sound panel to the mainboard. Mine has two USB jacks, one for speakers and one mic-in.
Good luck, I hope I could give you guys some hints.
-budman
Windows 7 x64AMD Phenom II X4 955 BE4 GBRadeon HD5750
Windows 7 x64
Radeon HD5750
Realtek Onboard
Conclusion!?
Hi, I went through this discussion what I tried and worked:
1) One stereo plugged in front green output and one stereo plugged in rear green output - now under stereo settings you have two simulataneous stereo streams - four speakers in total.
If this doesn't work try to change settings in "Device advanced settings" in upper right corner of Realtec HD Audio Manager (mine is strange the options there work quite opposite way they should)
2) Plug the speakers as quadraphonic (black and green rear outputs). In Realtec HD Audio Manager go for quadraphonic settings. Don't go for "Speaker fill" it sounds awful! If you run the speaker test, it has to work for all four speakers.
And now all you have to do is to choose any sound effect from the "Sound Effects" menu. I went for "room". To my ears it sounds as 2 identical stereo streams then.
Closest thing to a solution as we're going to get tonight.
I know this thread is old as f***, but unfortunately we still have this problem in 2014. Reading through this thread i played around with some of the suggestions and found a solution not exactly mentioned on here. A huge part of my solution is made up of previously suggested solutions though.
What worked for me, as mentioned before:
1) In Realtek HD Audio Manager go to Sound Effects -> Environment -> change to "Room"
2) In Realtek HD Audio Manager go to Speaker Configurations -> set to "5.1 Speaker" (produces better bass then Quadraphonic, also do not enable "bass management")
This may have been mentioned as well, but not about to read these 5 pages over again to verify:
3) Go into Playback Devices -> Right click "Speakers" -> Properties -> Levels Tab -> Bring the "Front" volume down to 50%
This set up is working pretty nicely for me right now. Getting even sound from my 2 front speakers and my 2 back ones, bass is okay, only center speaker isn't working, but i can live with that for now. I was using iTunes music while playing with these settings, so im not sure how these settings translate to movies or games.
May not be the ultimate fix, but defiantly better then before, and until something better comes up.
Windows 8 Pro x64Intel i7 4930kCORSAIR Vengeance Pro 16GB (2 x 8GB) 1866MHzEVGA GeForce GTX 770 4GB Dual Classified w/ E...
Windows 8 Pro x64
Intel i7 4930k
Asus Sabertooth x79
EVGA GeForce GTX 770 4GB Dual Classified w/ EVGA ACX Cooler
HP w1907 -defiantly need to upgrade
SSD: Seagate 600 Pro 240GB
HHD: WD Black 1TB
CORSAIR AX860i
Corsair 540 Silver
Corsair H100i
Logitech MX5500
Logitech MX Performance
