HELP ME please!!! OS not genuine Help Help me,Amigos
casa747
12:57 AM
Hi all,I need your help. There's lot problem in my head now.
My netbook original OS is Win7 Starter 32-bit,my brother not know so much about OS.Then,he saw "window anytime upgrade",he try finding the product key in internet and i don't know where he found that,maybe at youtube. Suddenly when i open my netbook i saw win7 ultimate and "30-day to activation" :eek: lol!!!!:mad:
Before, i try change back my product key to win7 starter at my computer properties. But can't undo update T_T. Now my window running in "not genuine". My dekstop all black :cool: and at down corner left dekstop wrote "win7 build 7600,this copy of window is not genuine'
Now,I keep trying to change my product key,i try again go My computer and click properties try to change again but suddenly appear....
C:\window\system32\slui.exe "window cannot access specified device,path,or file.You may not have appropriate permission":(. I try find another ways,like use cmd to change my key but can't too. :rolleyes:
Then,I try to reinstall window use win7 starter oem dvd given,i copy to external HDD coz i'm using netbook. During "setup is starting" ,
"window cannot locate required file X:\Sources\install.wim" ERRor code=0x8007000D.That code maybe something about activation. Haihhhh:confused:,can someone help me please?
I I just want my netbook like new brand again.I want my win7 starter back and i want format my HDD. Act i only 14years old:party: n my english suck,hope you understand and..im not so good about computer:sarc: Please reply ASAP!! Gracias!! :cry:
window 7 starter 32bit
if you can, try to install using the cd. Grab an external cd drive and use that.
Windows 8 ProfessionalAMD Phenom II X68 GBXFX ATI Radeon 4890
AMD Phenom II X6
ASUS
8 GB
XFX ATI Radeon 4890
Dual 22" LCD
PC Drives
HD0 = Crucial SSD 128gb Sata III
HD1 = 300gb (Seagate Barracuda)
NAS
HD0 = 1.5TB (Maxtor) Raid1
HD1 = 1.5TB (Maxtor) Raid1
HD2 = 1TB (Segate) Raid5
HD3 = 1TB (Segate) Raid5
HD4 = 1TB (Segate) Raid5
HD5 = 1TB (Segate) Raid5
750 watt
Razr Mamba
50 down 35 up FIOS
He used an illegal upgrade key making your OS illegal too
If your laptop has a recovery partition use it to restore the OS to default state
Windows 10 Pro x64, Arch LinuxIntel Core 2 Quad Q8200 OC'd 3.08GHz8GB DDR2 900MhzMSI GT730 2GB GDDR5 (Kepler)
Asus Rampage formula LGA775
8GB DDR2 900Mhz
Supreme FX2
Samsung LS22F350 LED
1080P
Kingston SSDNow UV400 120GB, 500GB Hitachi, 2TB Samsung, 500GB Seagate FreeAgent, 640GB Samsung, 160GB Toshiba (Arch)
AeroCool 500W Bronze
Cooler Master V6 + 3X fans
Prolink keyboard
Logitech M705
1MiB/s
Chrome Beta
Calm down, the feds are not after you. Lets do an experiment if you're upto it. Anytime upgrade would have created a restore point, so run system restore to revert to that point. I think you'd be easily able to make out that point in the SR options. If that runs successfully and you find Starter restored, you can enter the COA key on the back of your computer and activate.
OTOH, if you're not upto it, just insert your recovery disks (hopefully you made them) and restore to factory default. If you didnt make them, there are other options, let us know.
Too many to describe...
To explain further,
Feds is Federal Bureau of Investigation aka FBI
SR is System Restore
COA is Certificate Of Authenticity
OTOH is On The Other Hand
Quoting Bill
Calm down, the FBI are not after you. Lets do an experiment if you're upto it. Anytime upgrade would have created a restore point, so run system restore to revert to that point. I think you'd be easily able to make out that point in the System Restore options. If that runs successfully and you find Starter restored, you can enter the Certificate Of Authenticity key on the back of your computer and activate.
On The Other Hand, if you're not upto it, just insert your recovery disks (hopefully you made them) and restore to factory default. If you didnt make them, there are other options, let us know.
Sorry, couldn't resist ;)
Windows 7 Ultimate x64 (XP, 98SE, 95, 3.11, D...Intel Core 2 Duo Processor P8600 (2.40 GHz, 3...4GB 800 MHz DDR2 SDRAMATI Mobility FireGL V5700 with 256 MB
1280 x 800
500GB + 1TB
4 Mbps
Firefox, Chrome, IE
Not to take away from the gravity of the OP's situation....but I've noticed the only acronyms that self-expand are win7 and AFAIK. IIRC doesnt expand, neither does OTOH, neither do some less charitable ones. Somebody needs to do an analysis...
lunarpancake: yah..i'll try soon
yowanvista :nope:o
I have try use system restore but not have starter restored. And actually i don't get at all, just a little bit..by the way thanks so much spending time here reading my post. It will be nice if someone show me guide-by-guide to solve my problem :p .I know...it's my mistake not make backup file or system image or whatever...when first time i use this netbook. So..what should i do,just stay using this illegal window7 ultimate? Need i go to shop for repair or something? or format my com? i don't know la..give me some advice please.:o
THANK YOU,May god bless you
8GB DDR2 900Mhz
Supreme FX2
1080P
Prolink keyboard
Logitech M705
1MiB/s
Chrome Beta
I don't think he has a disk Yowanvista.
Estoy buscando alguien que es fluido en español ayudarle.
I am looking for someone who is fluent in Spanish to help you.
Babel Fish translator.
Hopalong/ Godzilla
ASUS P7P55D-E PRO
VIA Onboard
1920x1080; 1440x900
Samsung 830 120GB SSD
Intel 320 120GB SSD
Logitech K-320
Kensington
Avast Inernet Suite
IE 9 ; Chrome
OP mentioned he has an OEM disk
8GB DDR2 900Mhz
Supreme FX2
1080P
Prolink keyboard
Logitech M705
1MiB/s
Chrome Beta
As Bill nicely wrote; you have no other way other then:
Option 1. To format your PC after copying the documents, videos, music or other files you need to use and have no copy other than in HDD. Though, if you format and install Win 7 on the same partition, all your documents will be in that partition as Windows.old, but it is better to take a frank copy paste/ burning to dvd/cd (may not be applicable for you).
Format your Netbook using the media came with (if so) your netbook. You have to enter the COA key on the back of your computer and activate. (as Bill already said).
If you have purchased a branded notebook (most probably you have), but have no disk; you must contact your system manufacturer.
Warranty most probably will not cover the charge though.
Option 2. Buy a retail copy of windows 7 Ultimate if you want to use ultimate or Home Premium.
Windows 7 Ultimate 64 bit, Mac OS X 10.6Intel Pentium Dual Core @2.0GHz12GBNVIDIA Graphics For Mobile 512MB VRAM
COMPAQ Presario Laptop
Compaq Generic
12GB
IDT High definition Audio
Laptop LCD Display
1280*800 Bright View Widescreen
500 GB Primary Master@7200rpm + 1 TB External HDD
Direct ; generic fan
Generic Laptop Keyboard
Touch Pad
3.1 Mbps wireless Broadband
Generic Dock
Ooops! My bad Yowanvista.
Hopalong/ Godzilla
ASUS P7P55D-E PRO
VIA Onboard
1920x1080; 1440x900
Intel 320 120GB SSD
Logitech K-320
Kensington
Avast Inernet Suite
IE 9 ; Chrome
Hopalong/ Godzilla
ASUS P7P55D-E PRO
VIA Onboard
1920x1080; 1440x900
Intel 320 120GB SSD
Logitech K-320
Kensington
Avast Inernet Suite
IE 9 ; Chrome
First, welcome to the Seven Forums, Casa747.
If I have understood you correctly, I think you can not use repair install. When upgrading Windows with Anytime Upgrade, the operating system is upgraded. Repair install works as an in-place upgrade to the same operating system, replacing system files, and you can not in-place upgrade for instance a Home Premium or Professional with Starter.
The same thing with system restore. I've only done Anytime Upgrade once but as far as I can remember, doing this deleted the earlier restore points.
In my opinion your best chance to get everything back as it was is to reinstall Starter either from recovery partition, or from DVD using external hard disk.
Two questions: Can you, or your brother maybe, use BIOS to change the boot order (orden de inicio) of your netbook? Do your netbook have a partition named "Recovery"?
And please, could you tell us the name and exact model of your netbook.
Kari
HP ENVY 17-1150eg
Windows 10 Pro x64 EN-GB
1600*900 (1), 1920*1080 (2&3)
Logitech Performance Mouse MX
50/10 Mbps VDSL
Windows Defender 4.3.9431.0
Maxthon 3.5.2., IE11
You are 100% right. Plus his brother may actually have downloaded a crack, which may have malwares ; so, it is better to format (plus use Antivirus + Antimalware checking).
Compaq Generic
12GB
Laptop LCD Display
Touch Pad
Generic Dock
En primer lugar, Bienvenido a los foros de siete, Casa747.
Si le he entendido bien, creo que no puede utilizar la instalación de reparación. Al actualizar Windows Anytime Upgrade, se actualiza el sistema operativo. Reparación instalar obras como una actualización in situ el mismo sistema operativo, reemplazar archivos de sistema, y usted puede no en el lugar de actualización para la instancia de un Home Premium o Professional con Starter.
Lo mismo con la restauración del sistema. He sólo hecho Anytime Upgrade una vez, pero en lo que respecta a puedo recordar, haciendo esto elimina los puntos de restauración anteriores.
En mi opinión es su mejor oportunidad para obtener todo atrás como lo fue reinstalar el inicio de la partición de recuperación, o de DVD con disco duro externo.
¿Dos preguntas: puede usted, o su hermano tal, utilice BIOS para cambiar el orden de arranque (orden de inicio) de su netbook? ¿Hacer su netbook tiene una partición denominada "Recuperación"?
Y por favor, podría decirnos el nombre y el modelo exacto de su netbook.
Kari
Tranlsted Kari.
If you "blue" select your posting and right click as you would for copy you may have as I do Bing Translator listed.
Click and in new Window you can translate by selecting "To Spanish". Copy and Paste back as I did Kari's posting.
Then you have English and Spanish version to post.
Mike
Hopalong/ Godzilla
ASUS P7P55D-E PRO
VIA Onboard
1920x1080; 1440x900
Intel 320 120GB SSD
Logitech K-320
Kensington
Avast Inernet Suite
IE 9 ; Chrome
"Los foros de siete" :)
HP ENVY 17-1150eg
50/10 Mbps VDSL
Look in All Programs for Recovery, possibly under the maker's name. Select it to run Factory Recovery. Back up your files first.
You should also be able to run Factory Recovery from the first boot screen, by tapping the key given to Run Recovery. If it is not made clear on the first boot screen, look in your Manual on the SUpport Downloads webpage for your model.
Where did you get the Win7 Starter OEM Installation DVD? Has it been used before so you know it works?
Try extracting the ISO from the Starter DVD using ImgBurn, then write it to flash stick to use as a bootable installer. The easiest method is to install free UltraISO trial: On file tab Open ISO, on Bootable Tab, Write Disk Image, Format, then Write.
Now boot the stick using the one-time BIOS Boot Menu, or set the flash stick (sometimes listed under Hard Drives) in BIOS setup as first to boot, before HD.
Thx,i know about it. But,what is puzzle me now is when "setup is starting" then install.win problem and error code 0x8007000D. Maybe that file not correct image or what?. I check in my HDD install.wim is exist and that file is largest size. I try open install.wim use 7-zip,but only have {1}.xml file.
ouh..i see
