Installation Problem ("System could not create a partition...")
Doxq
6:27 PM
In the last couple days I've been trying to install Windows 7 over Windows XP (clean installation).
Unfortunately I'm having a problem pretty early on in the process. Whenever I try to press "Next" on the screen that has you select which partition you want to install it on, it says for me:
"Setup was unable to create a new system partition or locate an existing system partition. See the setup log files for more Information"
I've tried deleting all of them, making a new one a certain size etc. with no luck. I even tried to load the C: drive but it said it wasn't able to reformat it for whatever reason (message I get is "Windows can't format C. Check to see that the disk and drive are formatted properly. Make sure that the disk is not read only, then try again.") I've tried logging into Windows in Safe Mode to change the security options for this problem but I don't see any preference about read-only properties.
I have also tried going through the steps in the stickied thread about this problem (using diskpart to mark a partition as active) and it hasn't worked.
(I am trying to wipe my computer completely clean and install Windows7, not along side XP or anything like that).
Anything you could suggest would be great, thanks in advance.
Windows XP
Did you run the WIn7 upgrade advisor to find if your hardware can run Win7? http://www.microsoft.com/windows/windows-7/get/upgrade-advisor.aspx
If you still have XP on the HD, update the BIOS to latest version from maker's Support Download's webpage for your computer or mobo model .
Boot the Windows 7 installer, press Shift F10 at bootup, opening a Command Line, type:
DISKPART
LIST DISK
SELECT DISK # (for Windows 7 disk)
clean
create partition primary
select partition 1
assign letter=c:
active
format
exit
Now boot back into installer to Custom install to partition you created.
If there are further problems, please reset the CMOS: Clear CMOS - 3 Ways to Clear the CMOS - Reset BIOS
Also in BIOS setup, check the SATA controller setting: Try AHCI first, then IDE if neccessary.
If these all fail, post back your System Specs at link in bottom left corner of your post.
DISKPART
LIST DISK
clean
select partition 1
assign letter=c:
active
format
exit
This worked like a charm. It installed without any problems (on it now!). Thanks so much!
Windows XP
Did you run the WIn7 upgrade advisor to find if your hardware can run Win7? Windows 7 Upgrade Advisor - Download - Microsoft Windows
DISKPART
LIST DISK
clean
select partition 1
assign letter=c:
active
format
exit
Asus striker 2 formula
Intel Q9550 2.83 quad
8Gb G.Skill 2gb X 4 DDR2 ( I took out 3 sticks so 2gb ram for install)
Brand new Seagate barracuda 500 gb hdd 16MB 7200 rpm
GTX 570 twin frozr 3
Hangs up at expanding windows files still after I did this.
Please get back to me if you have any ideas. :)
Custom Build Desktop
MS Windows XP Professional 32-bit SP3
Intel Core 2 Quad Q9550 @ 2.83GHz Yorkfield 45nm Techn
SUSTeK Computer INC. STRIKER II FORMULA (Socket 775)
G.Skill 2.00 GB Single-Channel DDR2 @ 399MHz x4
1279MB GeForce GTX 570 (MSI)
466GB Seagate ST500DM002-1BD142 (SATA)
Where did you get Win7? Did you burn the disk or write it to flash stick yourself?
I bought it like yesterday. Its on a disk
I tried to boot it both on a USB and CD both didn't work. They hung at expanding windows files. I bought a new HD to see if that was the issue....installed it ..same problem...I was blue screening with winxp for some reason I'm not aware of. So I bought win7
With the new hdd installed I'm going to install winxp then win 7 over it..maybe that'll do it?
Clean install. So no upgrade advisor. I checked for latest bios before, I'm fully up to date. Already cleaned/formatted it in cmd in win 7 install. I'll try the memtest but I'm on a phone.right now hah.
Winxp installs fine even on my other hdd. But on old hdd it was blue screening so I'm tying.it out on the new one.
Ikahn,
Where did you get your Win 7?
AMD A10-4600M
AMD Pumori (Socket FT1)
AMD Radeon HD 7660G
High Definition Audio Device
1600x900@60Hz
Standard PS/2 Keyboard
I made the ISO from the disk. Its the latest version with sp 1.
I bought in from newegg.com.
I did the bios reset though
Still no dice.
But I don't know how to set my bios to AHCI. That could be the issue.
Right now gunna install win xp pro sp1. Update to sp3 and try to boot disk from desktop.
I've been stuck for a week any help would overjoy me lol
1. Did you get a 25-character Product Key? Did the DVD come in original packaging?
Do NOT put the key into your post. That's what costs the money and not the DVD.
2. Ikahn:
Update your system specs to best of your abilities.
Your present entry there is a joke and completely useless.
Don't forget to enter the manufacturer of the computer and the model.
3. Once you get XP installed, then the first order of business is:
Run the Upgrade advisor: Windows 7 Upgrade Advisor - Download - Microsoft Windows
There is no sense in trying to install Win 7 if the advisor says you have serious problems.
Include the Advisor report in your next post.
That's three points.
Carry out all three.
AMD A10-4600M
AMD Radeon HD 7660G
1600x900@60Hz
OK thank you both
All 3 win7s I bought came in orig packages. I know the key Is what you pay for lmao. The other 2 installs I did with the other 2 copies worked fine...no problems at all. I just finished installing win xp sp3 I'm going to get my internet setup then I'll do the upgrade advisor and report back.
When you've finished with the tasks at hand, let us know.
AMD A10-4600M
AMD Radeon HD 7660G
1600x900@60Hz
1. Bought 3 copies from Newegg.com. The windows cd's/keys arent the problem trust me.
2. The txt file is from speccy it should give you all the info you need. If not ask me for more :]
3. I downloaded and ran it. Says I have no problems really. I dont know how to save it so i can upload it here. Will a screen shot suffice?
