PROBLEMS WITH WIN 7 really need help from a tech
sebastian869
11:18 AM
[FONT=&quot]Hii, I have a SSD C: drive, for some reason now im having issues and Id like to run system restore. The thing is that I have turned off the generic system restore setting from c: drive to D: drive as it’s a generic raptor HD and for some reason it’s not simply letting me do so. I have win 7 Home premium.[/FONT]
[FONT=&quot]Just so I learn in the future, what is the best way to back up you pc over time when u have a limited space SSD and have to turn to a “D” drive.[/FONT]
[FONT=&quot]Thanks,[/FONT]
[FONT=&quot]Sebastian
[FONT=&quot][FONT=&quot][FONT=&quot]When i was trying [FONT=&quot]to load a .docx file this is what i [FONT=&quot]got[FONT=&quot]:
[FONT=&quot]Winword.exe system error
the program cant start beacuse oart.dll is missing
from your computer . Try reinstalling the program to fix
the problem
[FONT=&quot]Dont know wh[FONT=&quot]y a[FONT=&quot]nd i cant run system restore as i hav[FONT=&quot]e system "[FONT=&quot]backu[FONT=&quot]p[FONT=&quot]" on drive d not c[/FONT][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT]
[/FONT][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT]
windows 7 x64 home premiumi7-4790k16GB Corsair CMZ16GX3M2A2133C10swaping bad Asus 780ti GTX780TI-DC2OC-3GD5 fo...
selp built
i7-4790k
Asrock extreme6 Z97
swaping bad Asus 780ti GTX780TI-DC2OC-3GD5 for 970 or 980
Samsung 850Pro MZ-7KE256BW, Wester Digital VelociRaptor WD 1000DHTZ 1TB 10,000 R.P.M. 64MB Cache
microsoft security essentials
explorer 11 and chrome/firefox
well; I believe to best way to back up your pc is to use a backup device. As for the problem you are having; try checking for newer device drivers on the mfrs support site; download and install the new ones if available and see what happens.
Windows 7 ultimate 64-bitIntel I7 2600K 3.4ghzCorsair 16gb ddr3 1600mhzNvidia Geforce gt 430
custom built
Asus Evo P8P67
Sound Blaster Titanium x-fi pci express
Dell E198WFP
1 western digital 2TB drive.
Antec 1200 watt
Inwin Dragon Rider
6 case supplied cooling fans
logitech mk700
logitech m705
25-50mbps download; 10mbps upload(i think)
avg free 2014
mozilla firefox
Also have a pretty bad speaker setup which is a klipsch promedia 5.1 surround speaker setup with huge subwoofer and lg blu ray player/writer. Also a hp officejet pro 8600 plus wireless all in one and a logitech s7500 webcam.
Not sure I'm following you.
In your second sentence, you say you've turned off "generic" System Restore. I'm not sure what that means, but if you turned it off, I don't expect you'd get satisfactory results if you attempt to run it.
You ask "what is the best way to back up you pc over time when u have a limited space SSD and have to turn to a “D” drive".
You should use imaging. You make an image file of one or more partitions found on the SSD and store the image files on the D drive. If you get in a jam, you "restore" the image file by booting from a recovery disk. Macrium is the typically recommended tool--it's a free download.
Dell S2340M 23 inch IPS
1600 x 900
Antec Solo II
Microsoft 200 6JH-00001 USB
Pale Moon
When i was trying to load a .docx file this is what i got "Winword.exe system error
the problem"
You might try running the following command from a command prompt. It might help with the missing DLL problem:
sfc /scannow
If that fails, try a repair installation of Word.
I do have oart.dll on my system and don't know why it would be missing from yours.
1600 x 900
Antec Solo II
Pale Moon
