Windows Live Mail - Minimize to System Tray in Windows 7
    How to Minimize Windows Live Mail to the System Tray in Windows 7
    This will show you how to have Windows Live Mail minimize to the taskbar or system tray in Windows 7.
    EXAMPLE: Windows Live Mail Minimized to Taskbar by Default
    EXAMPLE: Windows LIve Mail Minimized to System Tray
    Here's How:
    1. If open, close Windows Live Mail.
    2. Right click on a Windows Live Mail shortcut or the wlmail.exe file, click on Properties, then click on the Compatibility tab. (see screenshot below)
    3. To Always Have Windows Live Mail Minimize to Taskbar
    A) Uncheck the Run this program in compatibility mode for box, and click on OK. (see screenshot above)
    B) Go to step 5.
    4. To Allow Windows Live Mail to be able to Minimize to System Tray
    A) Check the Run this program in compatibility mode for box, select Windows Vista (Service Pack2), and click on OK. (see screenshot below step 2)
    B) Open Windows Live Mail, and right click on the e-mail icon in the system tray. (see screenshot below)
    C) To Toggle Windows Live Mail to Minimize to System Tray
    • Click on Hide window when minimized to check it. (see screenshot above)
    D) To Toggle Windows Live Mail to NOT Minimize to System Tray
    • Click on Hide window when minimized to uncheck it. (see screenshot above)
    5. You will now be able to minimize Windows Live Mail to the taskbar or system tray.
  1. Posts : 50
    Windows 7 Home Premiun 64bit
    I tried this and it didn't work. I'm running Windows 7 64 bit.
  2. Posts : 1,730
    Windows 10 Pro 64 bit
    Hi rwmol, did you try from the dropdown menu, run this compatibility mode for Windows 7. Something else
    to try if you have not.
  3. Posts : 50
    I ran it in Compatibility Mode for Windows 7. I do not get the option to "Hide The Window When Minimized" from the drop down menu.
  4. Posts : 72,058
    What does it do if you select Windows Vista (Service Pack2) (as per tutorial) instead for the compatibility mode?
  5. Posts : 50
    Yes, I tried that too with no success. Perhaps the 64 bit is an issue.
  6. Posts : 72,058
    32-bit or 64-bit wouldn't matter.
    It appears that this may no longer work for Windows Live Mail.
  7. Posts : 50
    Not a big deal. I have a small program that sits in the system tray and notifies me when mail arrives at the server. I can delete unwanted mail before it arrives at my computer. Thanks anyway.
