I need help for a weird problem.
Nope, can't get Tfc from there... Let me find an other download site
Windows 7 Ultimate 32bit SP1
INTEL/D975XBX2
ATI Radeon HD 2600 Pro
Samsung SyncMaster 914v
1280 x 1024
One is not connected
Rocketfish 700 W
G.Skill Gigabyte Chassis
Standard PS/2 Keyboard
Microsoft PS/2 Mouse
DSL
Avira Internet Security
IE 11
ATI HDMI Audio
I just got it from there and have run it.
* BFK Customs *
W 7 64-bit Ultimate
Intel Q9550 Yorkfield
ASUS P5Q Pro
8GB Dominator 8500C5D
ATI : XFX 5870
Realtek HD Audio 7-1
1920x1080P & 1920x1200
Corsair 620HX
Cooler Master RC-690
Microsoft 500
Razer Diamondback 3G
14 Mb/s
Win 10 Pro x64
Intel I5-2500K @3.3GHz
Asrock P67 Extreme4
EVGA GeForce 750 Ti SC 2GB
auria eq2367
250GB Samsung 850 EVO SSD
1TB WD Blue
1TB Hitachi
SeaSonic X 650W 80 Plus Gold
Corsair Obsidian 750D
Logitech Wireless Mouse M310
Wave Broadband ~ 100 dn 5 up
Edge, IE11, Chrome
Laptop specs: HP g7-1365dx /
RAM: Crucial 8Gb (2x4Gb) /
GFX: AMD Radeon HD 6520G /
OS: Windows 10 Pro x64
:geek: it was giving me 'fits' earlier :thumbsup:
INTEL/D975XBX2
1280 x 1024
Rocketfish 700 W
DSL
IE 11
ATI HDMI Audio
2h30 later and over 200k files looked at, NIET!!
Acer Aspire 6920g
MS Windows 7 Home Premium 64-bit
Intel Mobile Core 2 Duo T5750 @ 2.00GHz
Acer Aspire 6920 (U2E1)
4.0GB Dual-Channel DDR2 @ 332MHz (5-5-5-15)
512MB GeForce 9500M GS (Acer Incorporated [ALI])
Generic PnP Monitor @ 1366x768
313GB Western Digital WDC WD3200BEVT-22ZCT0 (IDE)
optical drive : MATSHITA BD-CMB UJ-120 ATA Device
Next update the BIOS from Windows which is the safest method. Follow the Read Me steps exactly.
Test your memory using memtest86 CD for 5-6 passes and maker's HD diag/Repair full CD scan: http://www.tacktech.com/display.cfm?ttid=287
Next back up your files, gather your program installers, wipe the HD of all code and clean reinstall to overcome the likely effects of an in-place Upgrade gone bad: http://www.sevenforums.com/tutorials/1649-clean-install-windows-7-a.html
http://www.sevenforums.com/tutorials/31402-clean-install-upgrade-windows-7-version.html
Wipe the HD using this method: http://www.sevenforums.com/tutorials/91339-ssd-hdd-optimize-windows-reinstallation.html
The installer is mostly driver-complete with newer arriving quickly via optional Windows Updates. Any drivers then missing in Device Managercam be found on the Support Downloads webpage for your computer or device model. Only change out drivers if performance dictates, first the chipset then display driver.
Install programs slowly to gauge performance after each. Don't let any programs write themselves into msconfig>Startup besides AV and gadgets. Use free MS Security Essentials for the leanest least intrusive AV.
When you've finished, clean and order the HD perfectly with CCLeaner ("Run CLeaner" and Registry tabs) then Auslogics Disk and REgistry Defraggers monthly.
Watch the Event Viewer>Admin View closely to google repeat errors to resolution. In Advanced Tools also watch Performance Log and Generate a System Health Report.
Test your memory using memtest86 CD for 5-6 passes and maker's HD diag/Repair full CD scan: Hard Drive Diagnostics Tools and Utilities (Storage) - TACKtech Corp.
I went to Acer's site and downloaded the 1.16 bios update, but My comp says that I don't have the permission to use the phlashnt.sys driver. (even though i am administrator and every program was closed)
edit : memtest doesnt work for 64bit
edit : that fullscan for the harddrive will take about 50h... it is normal ?
Acer Aspire 6920g
INTEL/D975XBX2
1280 x 1024
Rocketfish 700 W
DSL
IE 11
ATI HDMI Audio
Acer Aspire 6920g
Have you tried install when disabling the UAC?
Or might want to try it in safe mode...
EDIT:
You might want before re-install the Bios to "Unblock" all the files inside the extracted folders by right click each files, then follow what it says.
But i doubt it is something to do within the bios update, you have another prob somewhere.
Asus P8Z77-V LE PLUS
Asus Dual-RX480-O4G
Asus IPS 23"
Internal:
500Go Sata 6Gb/s (x2)
500Go Sata 3Gb/s (x2)
SSD 60Go Sata 6Gb/s
Thermaltake Chaser A71
Custom Water Cooling Loop
Cooler Master QuickFire XTi
Razer Imperator 2012 (4G)
IE 11.0.xxx Rtm
Unless someone else here can walk you through these specific BIOS update complications or knows Acer BIOS updates well enough to advise you, I would call Acer tech support to help you as this is one operation you cannot get wrong.
If you have already tried a clean reinstall to zeroed HD, tested memory and HD, swapped cables, cleared CMOS, tried each SATA controller setting (first AHCI, then IDE) and all other steps given, then the only thing that is still missing is the BIOS update which can't be ignored as a suspect.
If you have not tried any of these fully and to completion with results noted, then ask back for further info if needed.
