Solved Problem with USB speed
andrew129260
IT Support Pro
5:30 PM
Hi everyone. I am having a major issue with slow USB speeds (1.30MB/second usb 3.0). I thought I had solved it but apparently not. Slow speeds occur on every USB port.
I have attached a screenshot of my device manger and the usb ports that are no my system.
Note: I have no hubs or anything installed like that. All usb ports are built in on motherboard except my four front ports on my case, that is directly connected to usb 3.0 adapter on the motherboard.
*Yes there are a mix of usb3.0 and usb 2.0 sorry.*
Anyways, this is what I have done:
1.) Selected better performance for flash drives and my external hard drive.
2.) Disabled usb selective suspend. Set power options to performance before that.
3.) Uninstalled ALL (including hidden devices ones) usb devices.
4.) Made sure bios is up to date - it is. Made sure settings for usb devices was all enabled and set to fastest setting.
5.) Reinstalled Windows 7 pro sp1 x64
6.) Have all windows updates and optional.
7.) USB drivers are up to date for both times before reinstall and after.
8.) I have tried disabling my avast antivirus when copying files, still no luck.
9.) Under device manager I have checked power management tab for ALL usb devices and disabled it from turning off the device to save power...
Anyone have any ideas? I am out of them....
PS Thanks again.
Windows 10 Pro
Motherboard Built in
Wired Dell keyboard
Wireless Logitech mouse
250mb down, 30mb up
Panda Cloud Antivirus
Chrome-ish x64
hey andrew you aren't showing any indicator of USB 3.0 spec there.
All the USB ports on a PC are likely not ALL 3.0's, mine, albeit a 2 year old motherboard, has only 2 actual USB 3.0 ports, and if you don't use a USB 3.0 hub or what's call a SPEED cable for USB compatibility, you'd have to directly connect the USB 3.0 devices to those specific ports otherwise it's likely 2.0 or worse 1.x.
Plus of course the drives themselves need to be USB 3.0
Motherboard handling of USB varies, I had to install a specific driver, I have attached my device manager listing.
I bought more expensive ($22) hubs and speed (USB 3.0 spec) extension cable to get what I needed done.
I only have some external HD's that are USB 3.0's.
That clear anything up for you? [drivers for motherboard USB 3.0 controller is what I would be looking for]
Self Built Custom
Windows 7 Ultimate Retail Box (64-bit installed) + Service Pack 1
AMD FX-8350 CPU v1.15 (or 1.0F) BIOS was required!
MSI 890FXA-GD70
8G CAS-7 G-Skill DDR3 @1333 (2 fours) [mobo nonOC max rec'd]
Radeon HD 7950 [3 gigs of GDDR5] MSI Twin Frozr model
Realtek High Definition Audio (onboard mobo, ALC-889 chip)
2 WS LED Monitors: One LG One Viewsonic
1920 by 1080
SSD for OS: Samsung 840 Pro
SSD for VM and utilities: Adata SX900
7200 RPM SATA HDs for the rest: Hitachi and Seagate
Corsair TX850 - 850W max, in service since August 2010.
Thermaltake Armor A90
Thermaltake Spin Q CPU Cooler, in service since August 2010
Logitech G11
Logitech M310 Wireless
100 Megabit broadband supposedly upgraded from 50 (Cable)
Bitdefender Internet Security 2014 suite
Pale Moon 64-bit main, also IceDragon, Opera, and Maxthon.
CompTIA A+ certified (220-800 series) in July 2013.
Sorry yes, I have updated original post. I have 6 usb 3.0 and 10 usb 2.0. Two usb 2.0 on front and 2usb 3.0 on front.
The asmedia in device manager there are my usb 3.0 drivers. That's what it was called when i installed it from the motherboard cd. The cd said it was the drivers for my usb 3.0 ports. I didn't find any updates drivers on Asus website.
My other concern is maybe I have to many usb devices connected. My room is in the attic that was turned into a bedroom.
I have the following usb devices connected:
-A usb wireless adapter
-wireless mouse
-usb wired keyboard with 2 usb ports built in
-monitor with webcam and 2 usb ports built in that connects to my computer by usb.
With all those usb devices maybe they are competing with bandwidth? I don't use the usb ports on the keyboard or the monitor, so I could disable them if that would help. Trouble is I do not know if I could disabled the ports on the units themselves without disabling the port its on. As I need the webcam and keyboard to function.
Okay, I also forgot to mention I have tried disabling my avast antivirus when copying files, still no luck.
Hope that all makes sense.
Windows 10 Pro
Wired Dell keyboard
250mb down, 30mb up
Chrome-ish x64
That F: drive, what is it?
USB itself can handle a lot of devices (over 100), if it draws a lot of juice a USB device comes with it's own power source.
Fragmented files could slow you down, you did do thousands of files at once.
Self Built Custom
MSI 890FXA-GD70
1920 by 1080
Logitech G11
F drive is my Flash drive. I also want to add/point out when i plug ether my flash drive or external hard drive to another computer, the transfer rate is fantastic. Around 18MB/s
(Same music folder by the way.)
But my computer its slow...
By the way, disk defrag says it is not needed. 0% fragmented.
Thanks for your help again :)
Windows 10 Pro
Wired Dell keyboard
250mb down, 30mb up
Chrome-ish x64
I have ran out of ideas as to why this is happening...I just restarted and plugged my flash drive in. I started copying things off it to my computer. That was faster than before. 11MB /s
But then when I went to copy things to it, it was 3MB /s
I then tried using my external hard drive and that produced the same slow results. IT's like the speed gets slower the longer my computer is on. So weird....
And its fast 18MB/s when I plug into into another computer, even one that has been on for awhile..
I am transferring the same content (Music) so it does not result in different results.
Windows 10 Pro
Wired Dell keyboard
250mb down, 30mb up
Chrome-ish x64
Any more Ideas? Thanks everyone.
Windows 10 Pro
Wired Dell keyboard
250mb down, 30mb up
Chrome-ish x64
USB 3.0 has given me headaches on both of the rigs I bought this year, mainly from the USB 3.0 header at midboard. One was an ASMedia XHCI such as yours and my latest one is an Intel 8 Series EHCI. Granted I'm getting 10Mbps on my front ports on the Intel controller but it still throws up problems left right and centre.
EVGA GTX 980 Classified
Realtek Onboard
Samsung S27D390
240GB Intel 520 Series SSD |
Samsung 850 EVO 120GB SSD |
2TB WD Caviar Black |
2TB WD Caviar Green
Corsair HX850-80 Gold Modular
Cooler Master Silencio 650
Microsoft Sidewinder X4
Gigabyte M6900 optical
152mb
F-Secure
Firefox 38.0
Thanks for the reply. Yeah, I have no idea what is going on here. I have kinda given up. Don't know what else to do. I guess I'll just live with it. Maybe my motherboard mftr. ASUS will release a update for the board for speed issues with usb. Maybe I'll get lucky :)
I would call them about it, but I probably will be told the same things I have already done.
I do feel like its an issue with usb bandwith. But I like my keyboard and monitor. Just wish there was a way to prevent windows from seeing the usb ports on them that I don't ever want to use.
Windows 10 Pro
Wired Dell keyboard
250mb down, 30mb up
Chrome-ish x64
I'm not sure to be honest, all I have connected to my rig via USB is a keyboard, mouse and printer (which is hardly ever used) which are all USB 2.0, and a Hitachi Touro external HDD which is USB 3.0. Whenever I connect my Kingston Data Travellers to my front USB 3.0 ports I get the 'This device can perform faster when connected to a super speed USB 3.0 port'. I've reinstalled drivers over and over again but nothing seems to fix it, my rear ports all work fine so it's definitely something to do with the mid board headers.
Realtek Onboard
Samsung S27D390
2TB WD Caviar Green
152mb
F-Secure
Firefox 38.0
Looking at your jpg of Devise Manager, I don't see any USB 3.0 drivers installed. Every Windows machine I have seen well show USB 3.0 driveers specifically labeled as USB 3.0. Look at Faladu's shot of his devise manager, it shows the usb 2.0 drivers and the usb 3.0 drivers are listed specifically usb 3.0. I think you have a driver problem.http://www.sevenforums.com/members/faladu.html
Custom, Dell and Lenono LT's
Win8/8.1,Win7-U64, Vista U64, uncounted Linux distor's
AMD and Intell, 9590, 8350, i5 3570k
CFVFZ, GA990FXA, Z77e-itx
Corsair G Skill
Crossfired Sapphire HD 7950 Vapor-X, ASUS R9 280X TOP
Realtek ALC889
ViewSonic VX2770SMH 27" / ViewSonic VX2433 LCD 24"
1080i HD
Samsung SSD 840 Pro
OCZ Agility 3's
OCZ Vector's
WD's Blue, red, green, Velociraptors
Seagate USB3 & Hybrid's
ASUS Blu-Ray
ASUS DVD
Corsair AX1200i, Seasonice 850 Gold
Cooler Master HAF 922 & HAF 932, Lian Li Train case.
Air, Glacer 240L expanded, custom EK loop with duel D5's
Microsoft SideWinder X4 USB Keyboard / Logitech 250 PS2
Logitech G500 / MS wireless 5000
Best of 5ms / 75+ dn / 12+ up More or less.
MS esentials-MalwareBytes
Firefox Chromebook
Nope, the asmedia XHCI controller are the usb 3.0 ports.
I got them from my motherboard website for the 3.0 usb driver
SABERTOOTH 990FX/GEN3 R2.0 - Motherboards - ASUS
After downloading the driver under usb for the usb 3.0 ports, that asmedia XHCI is added to device manager. Also, I would like to point out it is not just 3.0 ports with slow speeds, it is 2.0 as well.
Which is why I am so confused.
Thanks again. Hopefully we can figure this out.
-Also wanted to say that this has happened even when it was just windows and the drivers installed. No other programs at all. Still slow speeds. Reinstalling did not help.
Windows 10 Pro
Wired Dell keyboard
250mb down, 30mb up
Chrome-ish x64
Yeah that's right, I had to get the same drivers for my ASUS F2A85-V Pro in my backup rig, it had an ASMedia XHCI controller at midboard which handles the front USB 3.0. On that particular machine I added a BitFenix USB 3.0 front panel to the mid board header but never got it working at USB 3.0 speeds.
Realtek Onboard
Samsung S27D390
2TB WD Caviar Green
152mb
F-Secure
Firefox 38.0
Anyone have any more ideas?
Windows 10 Pro
Wired Dell keyboard
250mb down, 30mb up
Chrome-ish x64
Corsair G Skill
Realtek ALC889
1080i HD
Samsung SSD 840 Pro
OCZ Agility 3's
OCZ Vector's
ASUS Blu-Ray
ASUS DVD
Firefox Chromebook
Thanks, but unfortunately this didn't work.
Windows 10 Pro
Wired Dell keyboard
250mb down, 30mb up
Chrome-ish x64
Run a ATTO benchmark test and post the results. You can see here the difference file size makes. These two are usb 3 through two different ports/drivers, same stick.
Corsair G Skill
Realtek ALC889
1080i HD
Samsung SSD 840 Pro
OCZ Agility 3's
OCZ Vector's
ASUS Blu-Ray
ASUS DVD
Firefox Chromebook
Thanks madcratebuilder. I will do this when I have time.
Windows 10 Pro
Wired Dell keyboard
250mb down, 30mb up
Chrome-ish x64
Not sure what happened, but I just copied some files over and its fast now. Tried it again and yeah, fast.....Only thing changed in my rig is water cooling. It's now copying at 20-40MBPS
??? idk, but thanks anyway!
Windows 10 Pro
Wired Dell keyboard
250mb down, 30mb up
Chrome-ish x64
