1. Start Windows 7, and log on to an administrator account.
2. Disable any 3rd party firewall, antivirus, or other security program to avoid it from possibly preventing the repair in-place upgrade installation of Windows 7.
3. Do either
step 4, step 5, or step 6 below depending if your
retail Windows 7 installation ISO/DVD/USB has SP1 or not, and if your currently installed Windows 7 has SP1 installed or not.
4. Repair Installed Windows 7 SP1 using Windows 7 with SP1 ISO
If you do not have a Windows 7 with SP1 ISO, then you can download an official ISO with your retail product key from Microsoft at the link below.
Microsoft Software Recovery
You can also download the latest official Windows 7 SP1 Media Refresh (SP1 U)
ISO file at the link below, but this link is not always available for download.
Microsoft: Windows 7 Direct Download Links
A) If you have not already, you will need to install a program like
7-Zip that supports extracting a ISO to a folder.
B) Using the program (ex: 7-Zip) from step 1, extract the Windows 7 SP1
ISO file to a folder on a partition or HDD other than the current Windows 7 partition. (see screenshot below)
NOTE: For example with 7-Zip, right click on ISO, click on 7-Zip, Extract files, browse button, select where you want to extract to, and click on OK twice.
C) While in Windows 7 SP1, open the folder that you extracted the ISO into, and run the
setup.exe file.
D) Go to
step 7 below.
5. Repair Installed Windows 7 SP1 using Windows 7 with SP1 DVD/USB
A) While in Windows 7 SP1, insert your retail Windows 7 SP1 installation DVD into the DVD drive, or connect your
Windows 7 with SP1 installation USB thumb drive, and click on the
Run setup.exe option in AutoPlay. (see screenshot below)
NOTE: If the AutoPlay window does not open, then open the drive folder in Computer and run the setup.exe file.
B) Go to Go to
step 7 below.
6. Repair Installed Windows 7 without SP1 using Windows 7 without SP1 DVD/USB
If you do not have a Windows 7 without SP1 installation DVD/USB, then you can download the latest official Windows 7 Professional or Home Premium without SP1
ISO file here:
Microsoft: Windows 7 Direct Download Links, and use
Windows 7 USB-DVD Download Tool to create a bootable DVD or USB flash drive with the ISO to do the repair install from within Windows 7 using this step.
It is preferred to have SP1 installed on your PC and to use
step 4 or step 5 above to do a repair install with instead though.
A) While in Windows 7 SP1 installed, insert your retail Windows 7 installation DVD into the DVD drive, or connect your
Windows 7 installation USB thumb drive, and click on the
B) Go to Go to
step 7 below.
7. If prompted by
UAC, then click on
Yes.
8. Click on the
Install Now button to start the installation. (see screenshot below)
9. If prompted, uncheck the
I want to help make Windows installation better box (unless you would like to :) ), and click on the
Go online to get the latest updates for installation option. (see screenshot below)
A) Windows 7 will now check online for and install any available installation updates. (see screenshots below)
10. Check the
I accept the license terms box, and click on
Next. (see screenshot below)
11. Click on the
Upgrade option. (see screenshot below)
12. Windows will now check for any compatibility issues. If any are found like in the example below, click on the red X to cancel the repair install and close this "Install Windows" window, take care of any found issues (ex: uninstall any incompatible program), then restart the repair install process over again.
13. The installation of Windows 7 will now begin. (see screenshot below)
NOTE: During the installation process, your screen may flash and computer will restart a few times.
14. After the final restart, you will see this screen for a moment. (see screenshot below)
15. Type in your Windows 7
product key number. (see screenshot below step 16)
16. Uncheck the
Automatically activate Windows when I'm online box unchecked, then click on the
Next button. (see screenshot below)
NOTE: You can activate Windows 7 later after you make sure it is running properly. (see step 23 below)
If you chose to automatically activate Windows online when you set up your computer, automatic activation begins trying to activate your copy of Windows three days after you log on for the first time.
17. Click on
Use recommended settings. (see screenshot below)
![note](https://www.sevenforums.com/images/smilies/notesmall.png)
You will always be able to change your
Windows Update settings at anytime in Windows 7.
18. Select your
time zone and set your
time and
date settings, then click on the
19. Click on the option for your computer's location to select the correct network location type settings to be applied for that location. (see screenshot below)
NOTE: It is best to select Public location for the best security.20. Windows 7 will now prepare your desktop to startup. (see screenshots below)
21. If you used a DVD or USB to do the repair install with, then you can remove the DVD or USB when the repair install has successfully completed and you are logged in to Windows 7.
22. Check to see if you are missing any user files. If you are, then you can copy them from the
C:\Windows.old or the
hidden protected operating system
C:\$INPLACE.~TR and
C:\WINDOWS.~Q backup folders. (see screenshot below)
23. If everything checks out in step 21, then you can run
Disk Cleanup (step 5 at this link). You will need to click on the
Clean up system files button first, and then could check the
Files discarded by Windows upgrade,
Previous Windows installations, and
Windows upgrade log files boxes. (see screenshot below)
NOTE: This will delete the C:\Windows.old, C:\$INPLACE.~TR and C:\WINDOWS.~Q folders from step 21 above.
24. Refresh your Windows Experience Index (WEI) score.
25. When finished,
activate Windows 7, and make sure that your 3rd party security programs (if applicable) are enabled again.
