Windows Live Mail - Turn Quick Views On or Off
    How to See All Email in One Inbox Folder in Windows Live Mail with "Quick Views"
    This will show you how to turn Quick Views on or off in Windows Live Mail to be able to see all email messages from all separate email accounts in one inbox folder.
    EXAMPLE: Windows Live Mail with Quick Views Turned On
    Here's How:
    1. Open Windows Live Mail, and click on the View tab.
    2. To Turn Off "Quick Views"
    A) On the right side of the ribbon toolbar, click on Quick views in the Layout section. (see screenshot below)
    3. To Turn On "Quick Views"
    B) On the left side of the ribbon toolbar, click on Quick views in the Views section. (see screenshot below)
    C) Check (turn on) or uncheck (turn off) the options you want to have displayed in your Quick Views folder, then click on OK. (see screenshot below)
  1. Posts : 168
    Windows 10 Home 64b
    Can the tab (the word Quick Views) be removed? i don't use it.
  2. Posts : 72,052
    I'm afraid not.
