Case air flow (Quick help please)
Dj SharK
2:52 AM
S.E.A
Right this moment, i'm building my first rig. I've always got a DIY system but it's set up by the people working at the store.
Not sure if i connect everything properly as i've yet to start it up. That's a different thing altogether.
My question: I have 2 fans installed. 1 is at the usual rear panel blowing air out. I've installed another up front (basically, in-between my HDD and front panel). Should the fan up front be blowing air out or in? Which would be better?
Thanks!
DIY
Windows 7 Ultimate x86 7600
Intel Pentium Dual CPU E2180 @ 2.00 GHz
Gigabyte G41M Combo (rev 1.3)
1 x 2GB | 1 x 1GB Kingston 667
512MB Nvidia GeForce EN8500GT Silent Magic
Onboard HD 7.1 Audio
22" LG W2242T
1680 X 1050
1 x 500GB SATA Hitachi ( Internal )
1 x 1TB SATA Hitachi ( Internal )
1 x 320GB Western Digital ( External )
500W
Coolermaster
Coolermaster
Logitech Media Wireless Keyboard
A4Tech G6 Wireless Mouse
DL : 12MB/s | UL : 1.2MB/s
I'm not a gamer. I don't overclock. I use my PC for web browsing, listening to music and watching HD movies.
It should be blowing in. pulling fresh air into the system...
SMN-Productions
Windows 7 x86/x64, Server 2008r2, Web Server 2008
i7 v2 3930K Steping stone 2
ASUS Rampage IV Extreme
G.SKILL Ripjaws Z Series 32GB
AMD HD 5770
Acer 21" and Samsung 20"
Patriot Pyro 80GB
1000 Watt
HAF-X
4 Fans
Black Widow Ultimate
Ah, cheers Mckill! I'll switch it around then. ;)
Rep'ed. :)
DIY
22" LG W2242T
1680 X 1050
500W
Coolermaster
Coolermaster
Dwarf Dwf/11/2012 r09/2013
Windows 8.1 Pro RTM x64
ASRock Z77 Extreme4-M
Iomega 1.5TB Ext USB 2.0
WD 2.0TB Ext USB 3.0
Gigabyte IF233
Avast! 8.0.1497
IE 11
Cheers Dwarf! Mine is set up exactly as you explained it. The front fan is near the bottom and the rear is up top.
I originally thought it's best to use both fans blowing hot air out but your message made complete sense.
I'll switch it around. ;)
*Can't rep you as i gave you one not too long ago. IOU1. :D
DIY
22" LG W2242T
1680 X 1050
500W
Coolermaster
Coolermaster
You're welcome. I'm glad it helped. :)
Gigabyte IF233
Avast! 8.0.1497
IE 11
