Windows 7 - Tutorial Index
Page 2 of 7 FirstFirst 1234 ... LastLast
  1. Posts : 72,062
    Windows 7 Tutorial Index - D (3 of 4)
    A - B - C - D - E - F - G - H - I - J - K - L - M - N - O - P - Q - R - S - T - U - V - W - X - Y - Z
    D:
    Disk Check
    How to Run Disk Check in Windows 7
    Disk Check AUTOCHK Initiation Countdown Time at Boot - Change
    How to Change AUTOCHK Initiation Countdown Time in Windows 7 and Windows 8
    Disk Check (chkdsk) - Read Log in Event Viewer
    How to Read the Event Viewer Log for Check Disk (chkdsk) in Vista, Windows 7, and Windows 8
    Disk - Check if MBR or GPT in Windows
    How to Check if Disk is MBR or GPT in Windows
    How to Clean or Clean All a Disk with the Diskpart Command
    Disk Cleanup - Add or Remove from Drive Properties
    How to Add or Remove "Disk Cleanup" from Properties Page of a Drive in Windows
    Disk Cleanup - Add to Context Menu
    How to Add "Disk Cleanup" to Context Menu of Drives in Vista, Windows 7, and Windows 8
    Disk Cleanup - Extended
    How to Use Extended Disk Cleanup in Vista, Windows 7, and Windows 8
    Disk Cleanup Extended - Add to Context Menu in Windows
    How to Add "Extended Disk Cleanup" to Desktop Context Menu in Windows 7 and Windows 8
    Disk Cleanup - Last Access Limit on Temp Files
    How to Set Disk Cleanup to Delete Vista or Windows 7 Temporary Files Less than a Week Old
    Disk Cleanup - Open and Use
    How to Open and Use Disk Cleanup in Windows 7 and Windows 8
    Disk Cleanup - Remove Outdated Windows Updates in Windows 7
    How to Remove Outdated Windows Updates in Disk Cleanup in Windows 7
    Disk Defragmenter - Open and Use
    How to Use Windows 7 Disk Defragmenter
    Disk Defragmenter Schedule - Turn On or Off
    How to Turn the Windows 7 Disk Defragmenter Schedule On or Off
    Disk Management - Add or Remove in Control Panel
    How to Add Disk Management to Control Panel in Windows 7, 8, and 10
    Disk Management - Post a Screen Capture Image
    How to post an informative screen capture of your Disk Management screen
    Disk - Recover Deleted Partitions in Windows
    How to Recover Deleted Partitions in Vista, Windows 7, and Windows 8
    Disk - Set as Offline or Online
    How to Change Status of a Disk to Offline or Online in Windows
    Disk Space - Free Up and Recover
    How to Free Up and Recover Hard Drive Space in Windows 7
    Disk Space Usage - Change for System Protection
    How to Change the System Protection (System Restore) Disk Space Usage in Window 7
    Disk Space Usage - Manage for Offline Files
    How to Manage the Offline Files Disk Space Usage in Windows 7
    Disk Quota Entries - Export and Import
    How to Export and Import User Disk Quota Entries in Windows
    Disk Quota - Set Space Limits for Users
    How to Set Disk Quota Limits for Users in Windows
    Disk Write Protection - Enable or Disable in Windows
    How to Enable or Disable Write Protection for a Disk Drive in Windows
    Disks (Local) - Enable or Disable Backing up to
    How to Enable or Disable Backing up to Local Hard Disks in Windows 7
    DISKPART : At PC Startup
    How to Boot to DISKPART at PC Startup
    Diskpart Command - Clean and Clean All a Hard Disk
    Display - Add "Turn Off Display" to Desktop Context Menu in Windows
    How to Add or Remove "Turn Off Display" Desktop Context Menu in Windows 7 and Windows 8
    Display - Change Main Display
    How to Change the Main Display in Windows 7
    Display Color Calibration
    How to Open and Use Display Color Calibration in Windows 7
    Display - Configure for Touch and Pen in Windows
    How to Configure Pen and Touch Displays in Windows 7 and Windows 8
    Display DPI Settings - Add or Remove from Desktop Context Menu
    How to Add or Remove "Display" from Desktop Context Menu in Windows 7 and Windows 8
    Display DPI Shortcut - Create
    How to Create a "Display" DPI Shortcut in Windows 7 and Windows 8
    Display Driver Uninstaller: How to use
    How to Use Display Driver Uninstaller to Uninstall any Installed Display Driver
    Display Language - Change
    How to Change the Display Language in Windows 7 Ultimate and Enterprise
    Display Language - Force to Overwrite All Users
    How to Overwrite the Display Language of All Users with the System Display Language
    Display Language Packs - Install and Uninstall
    How to Install and Uninstall Display Languages in Windows 7 Ultimate and Enterprise
    Display Language Packs - Create Install and Uninstall Shortcut
    How to Create a "Install or Uninstall Display Languages" Shortcut in Windows 7
    Display Presentation Mode
    How to Change the Windows 7 Display Presentation Mode
    Display Settings - Change Color Bit Depth
    How to Change the Color Bit Depth in Windows 7
    Display Settings - Enable or Disable
    Enable or Disable Changing "DPI" and "Screen Resolution" Display Settings in Windows 7 and Windows 8
    Display Switch Shortcut - Create
    How to Create a "Display Switch" Shortcut in Windows 7
    Display - Turn Off in Windows
    How to Set to Turn Off the Display after Specified Time in Windows
    DLL and OCX Files - Add or Remove "Register and Unregister" to Context Menu
    How to Add a Register and Unregister Context Menu to DLL and OCX Files in Windows
    DLL File - Create with Customized Icons
    How to Make Your Own DLL File with Customized Icons
    DNS Resolver Cache - Flush and Reset in Windows
    How to Flush and Reset the DNS Resolver Cache in Windows
    DNS Resolver Cache - View in Window
    How to Display Your DNS Resolver Cache in Windows 7, Windows 8, and Windows 10
    DNS - Setup OpenDNS in Windows 7
    How to Setup OpenDNS in Windows 7
    Do Not Display Last User Name - Log On with User Name and Password
    How to Make Windows 7 Require a User Name and Password in Log On Screen
    "Do you want to create a system repair disc?" Message - Hide or Show
    How to Hide or Show "Do you want to create a system repair disc?" Message
    "Do you want to scan and fix Removable Drive" Prompt - Disable in Windows
    How to Disable "Do you want to scan and fix Removable Drive" Prompt in Windows
    Documents and Programs - Run at User Logon
    How to Run Specific Programs and Documents at User Logon in Windows 7 and Vista
    DOM Storage "Cookies" - Enable or Disable
    How to Enable or Disable DOM Storage "Cookies" in Internet Explorer and Firefox
    Double-Click or Single-Click to Open an Item
    How to Open Items with a Single-Click or Double-Click in Windows 7
    Downgrade Windows 8 to Windows 7
    How to Downgrade Windows 8 to Windows 7
    Downloads Library - Create
    How to Create a "Downloads" Library with Correct Icon in Windows 7 and Windows 8
    DPI Display Size Settings - Change
    How to Change the Display DPI Size in Windows 7
    Drag and Drop Default Action - Change in Windows
    How to Change Default Drag and Drop Action in Windows
    Drag and Drop Sensitivity - Change in Windows
    How to Change Drag and Drop Sensitivity in Windows
    Drag Maximized Windows - Enable or Disable
    Enable or Disable Drag from Maximized Windows in Windows 7 and Windows 8
    Dragging and Dropping and Context Menus - Disable or Enable in Start Menu
    How to Disable or Enable "Context Menus and Dragging and Dropping" in the Start Menu
    DreamScene - Install in Windows 7 and Vista
    How to Install DreamScene in Windows 7 and Vista
    Drive Access - Restrict or Unrestrict
    How to Restrict or Unrestrict Drive Access in Vista and Windows 7
    Drive, File, Folder, or Program - Create Shortcut of in Windows
    How to Create a Shortcut of a File, Folder, Drive, or Program in Vista, Windows 7, and Windows 8
    Drive, File, Folder, or Registry Key - Take Ownership of
    How to Take Ownership of a Item in Vista and Windows 7
    Drive, Folder, and Library - Pin to Start Menu
    How to Pin a Folder, Drive, and Library to the Start Menu in Windows 7
    Drive - Hide or Unhide
    How to Hide or Unhide a Drive in Vista and Windows 7
    Drive Icon - Change
    How to Change a Drive Icon in Vista, Windows 7, and Windows 8
    Drive Letter - Add, Change, or Remove in Windows
    How to Add, Change, or Remove a Drive Letter in Vista, Windows 7, and Windows 8
    Drive Letter - Lock to a Hard Drive
    How to Lock a Drive to a Specific Letter
    Drive Letters - Hide or Show
    How to Hide or Show Drive Letters in Vista, Windows 7, and Windows 8
    Drive Letters - Show Before or After Name in Computer
    How to Show Drive Letters Before or After Drive Name in Vista, Windows 7, and Windows 8
    Drive - Map Network Drive
    How to Map a Network Drive in Windows 7
    Drive - Mark as Active
    How to Mark a Partition as Active in Windows 7
    Continued on next post......
  2. Posts : 72,062
    Windows 7 Tutorial Index - D (4 of 4)
    D:
    Drive - Mark as Inactive
    How to Mark a Partition as Inactive in Windows 7 and Vista
    Drive Permissions - Allow or Deny Users and Groups
    How to Allow or Deny Permissions to Users and Groups
    Drive - Pin or Unpin to Taskbar
    How to Pin or Unpin a Drive to the Windows 7 Taskbar
    Drive - Recover Deleted Partitions in Windows
    Drive - Rename
    How to Rename a Drive in Vista, Windows 7, and Windows 8
    Drive Space - Free Up and Recover
    Driver - Install Using "Add Hardware" Wizard
    How To Install a Driver in "Add Hardware" Wizard
    Driver Install - Add Printer Wizard
    How To Install a Driver in Add Printer Wizard
    Driver Install - Device Manager
    How to Install a Driver in Device Manager
    Driver selection for your Hardware devices
    Short tutorial for getting the correct device driver
    Driver for USB - General Fix for Problems
    General Fix for USB Driver Problems
    Driver - Install Vista Driver in Windows 7
    How to Install a Vista Driver in Windows 7
    Driver - Installing and Updating in Windows 7
    All the steps
    Driver - Roll Back in Device Manager
    How to Roll Back a Device Driver in Device Manager
    Driver - Turn Off Automatic Driver Installation
    Turn off Windows 7 Automatic Driver Installation
    Driver - Uninstall in Windows
    How to Uninstall Drivers in Windows 7 and Windows 8
    Driver Verifier - Enable and Disable
    How to Enable or Disable Driver Verifier in Windows 7
    Drivers and System Files - Verify if Digitally Signed in Windows
    How to Verify if System Files and Drivers are Digitally Signed in Windows 7, Windows 8, and Windows 10
    Drivers - Clean Left over Files after Uninstalling
    How to Clean Left Over Driver Files with DDU or Driver Sweeper
    Drivers - Find and Update Outdated Drivers
    How to Find and Update Outdated Drivers in Windows
    Drives - Hide or Show Empty Drives in Computer Folder
    How to Hide or Show Empty Drives in Computer Folder in Windows 7 and Windows 8
    Drives or Partitions - Mount as a Folder
    How to Mount a Hard Drive or Partition as a Folder in Windows 7
    Drives - "Send To" Context Menu - Add or Remove
    How to Remove or Show Drives in "Send To" Context Menu in Vista, Windows 7, and Windows 8
    Drives - Turn Off Hard Disk After Idle or Never
    How to Turn Off Hard Disk After so many Minutes of being Idle or Never
    Dual Boot - Change OS Name in Windows Boot Manager
    How to Change the OS Name in Windows Boot Manager
    Dual Boot : Create Partitions Using the PWBD
    Create a Dual Boot : Using the Free Partition Wizard Bootable Disk
    Dual Boot - Delete a OS
    How to Properly Delete a OS in a Dual Boot
    Dual Boot Installation with Windows 7 and Vista
    How to Setup a Dual Boot Installation with Windows 7 and Vista
    Dual Boot Installation with Windows 7 and XP
    How to Setup a Dual Boot Installation with Windows 7 and XP
    Dual Boot Installation - Windows 8 and Windows 7 or Vista
    How to Do a Dual Boot Installation with Windows 8 and Windows 7 or Vista
    Dual Boot - Remove and Uninstall Windows 7, Windows 8, or Windows 10 from PC
    How to Remove and Uninstall Windows 7, Windows 8, or Windows 10 from Dual Boot PC
    Dual Boot - Windows 7 and Linux
    How to Correctly Setup a Dual Boot with Windows 7 and LinuxMint13
    Dual Boot Windows 7 and Ubuntu
    How to Dual Boot Windows 7 and Ubuntu
    Dual Boot Windows 7 and Windows 8 - Delete Windows 7
    How to Delete "Windows 7" in your Dual Boot with Windows 8
    Dual Boot Windows 7 and Windows 8 - Delete Windows 8
    How to Delete "Windows 8" in your Dual Boot with Windows 7 or Vista
    Dump File - Change Default Location
    How to Change the Default Memory Dump File Location in Windows
    Dump Files - Configure Windows to Create on BSOD
    How to Configure Windows to Create a Dump File when you get a BSOD
    Dump Files - Upload to SevenForums
    DVD/CD Tray - Eject and Close - Add to Desktop Context Menu
    How to Add "Eject/Close CD/DVD Tray" to the Context Menu in Windows
    DVD and CD Drive Burning Features - Enable or Disable
    How to Enable or Disable Built-in CD and DVD Burning Features in Windows 7 and Windows 8
    DVD and CD Drive - Read and Write Access - Allow or Deny
    How to Deny or Allow Read and Write Access to CD and DVD Drives in Vista and Windows 7
    DVD and CD Drive - "You have files waiting to be burned to disc" - Stop Message
    How to Stop "You have files waiting to be burned to disc" Message in Windows
    Dynamic Disk - Convert to a Basic Disk
    How to Convert a Dynamic Disk to a Basic Disk
  3. Posts : 72,062
       #12
    Windows 7 Tutorial Index - E (1 of 2)
    E:
    Ease of Access Center - Add or Remove from Log On Screen
    How to Add or Remove Ease of Access Center from Windows 7 Log On Screen
    Ease of Access Center Shortcut - Create
    How to Create an "Ease of Access Center" Shortcut in Vista, Windows 7, and Windows 8
    "Edit" Context Menu - Change Default Program in Windows
    How to Change the Default Program of the "Edit" Context Menu in Windows
    Edit - Open - Print : Fix Missing in Context Menu when more than 15 Files are Selected
    Restore Missing "Open", "Print", and "Edit" Context Menu Items when more than 15 Files are Selected
    Eject and Close CD/DVD Tray - Add to Desktop Context Menu
    Elevated Administrator Account - Change Name
    How to Rename the Windows 7 Built-in Elevated "Administrator" Account
    Elevated Administrator - Enable from WinRE
    How to Enable the Built-in Elevated "Administrator" Account from WinRE
    Elevated "Administrator" Account - Enable or Disable
    How to Enable or Disable the Built-in Elevated "Administrator" Account in Windows 7
    Elevated Command Prompt
    How to Open an Elevated Command Prompt in Windows 7
    Elevated Command Prompt Shortcut
    How to Create an Elevated Command Prompt Shortcut in Windows 7 and Windows 8
    Elevated Program Shortcut - Create for Standard User
    How to Create an Elevated Program Shortcut Any User is able to Run in Vista, Windows 7, and Windows 8
    How to Create an Elevated Program Shortcut without a UAC Prompt in Windows
    Email Attachments - Download Multiple at the Same Time
    How to Download Multiple Email Attachments at the Same Time
    Email - New Message Shortcut
    How to Create a "New E-mail Message" Shortcut in Vista and Windows 7
    Email to a Common Contact Shortcut
    How to Create a New E-mail Message to a Specified Contact's E-mail Address Shortcut
    Email - Receive in Windows Media Center
    How to get your Emails in Windows 7 Media Center
    Emergency Kit - save your files from a dead OS
    How to Create and Use a Linux Mint Mate USB Flash Drive to Recover your Files
    Emergency Restart Windows
    How to Perform an Emergency Restart in Vista, Windows 7, and Windows 8
    EMET (Enhanced Mitigation Experience Toolkit)
    Empty Folder and Subfolders - Add to Context Menu
    How to Add "Empty Folder and Subfolders" to Context Menu in Windows
    Empty Recycle Bin - Add to Desktop Context Menu
    How to Add "Empty Recycle Bin" to Desktop Context Menu in Windows 7 and Windows 8
    Enabling Custom Themes - Windows 7
    How to Enable Custom Themes without Modifying System Files
    Encrypt and Decrypt - Add to Context Menu
    How to Add "Encrypt and Decrypt" to Context Menu in Windows 7 and Windows 8
    Encrypt or Decrypt a Folder or File
    How to Encrypt or Decrypt a Folder or File in Vista, Windows 7, and Windows 8
    Encrypt or Unencrypt Offline Files
    How to Encrypt or Unencrypt Offline Files in Windows 7 and Windows 8
    Encrypted File System (EFS) Certificate Backup
    How to Backup Encrypted File System (EFS) Certificate in Vista, Windows 7, and Windows 8
    Encrypted File System (EFS) Certificate Restore
    How to Restore Encrypted File System (EFS) Certificate in Vista, Windows 7, and Windows 8
    Encrypted Files - Find All on Local Hard Drives
    How to Create a List of All Encrypted Files on All Local Drives in Windows
    Encrypting File System Manager Shortcut - Create
    How to Create a "Encrypting File System Manager" Shortcut
    Encryption - Disable or Enable
    How to Disable or Enable EFS Encryption in Vista, Windows 7, and Windows 8
  4. Posts : 72,062
    Windows 7 Tutorial Index - E (2 of 2)
    E:
    Encryption - Enable or Disable for the Virtual Memory Page File
    How to Enable or Disable Page File Encryption in Vista and Windows 7
    End of Support Reminder Notifications for Windows 7 - Disable
    How to Disable Windows 7 End of Support Reminder Notifications
    Enhanced Mitigation Experience Toolkit (EMET)
    Error 0x8007000D when Editing MP3 Metadata - Fix
    How to Fix 0x8007000D Error when Editing MP3 Metadata
    Error Message - Where Does it Come From
    How to ID the Process that Issued a Error Message in Windows 7
    Error Reporting - Disable in Windows
    How to Enable or Disable Error Reporting in Vista, Windows 7, and Windows 8
    Event Viewer: Clear All Events
    How to Clear all Event Logs in Event Viewer using Windows PowerShell
    Event Viewer - Create a Custom System Monitoring
    Filtering and Creating Custom Event Views for System Monitoring
    Event Viewer - Email Notification
    How to Setup Event Viewer in Vista and Windows 7 to Send a Email Notification
    Event Viewer - Monitor Boot Times
    How to Monitor Boot Times in Event Viewer
    Event Viewer One Click Clear
    How to Clear Event Viewer with One Click in Windows
    Event Viewer - Open and Use in Windows 7
    How to Open and Use Event Viewer in Windows 7
    Event Viewer - Read Check Disk (chkdsk) Log
    Event Viewer - Read Memory Diagnostics Tool Log
    How to Read the Event Viewer Log for Memory Diagnostics Tool
    Event Viewer - Read Wake Source Log
    How to Read the Wake Source Log in Event Viewer for Vista, Windows 7, and Windows 8
    Event Viewer - View Log Details of Last Shutdown and Restart of Computer
    How to See the Last Shutdown and Restart Time of Your Vista, Windows 7, or Windows 8 PC
    Environment Variables Shortcut - Create in Windows
    How to Create an "Environment Variables" Shortcut in Vista, Windows 7, and Windows 8
    Excel - Create 3D Formulas
    How to Create 3D Formulas in Excel
    Explorer - Add "Restart Explorer" to Desktop Context Menu
    How to Add "Restart Explorer" to the Desktop Context Menu
    Explorer.exe - Kill all Processes at Once
    Kill All explorer.exe Running Processes with One Click
    'Extract All' Context Menu - Add or Remove in Windows
    How to Add or Remove 'Extract All' Context Menu for ZIP Files in Windows
    Extract Files from Windows 7 Installation DVD
    How to Extract Files from the Windows 7 Installation DVD
  5. Posts : 72,062
       #14
    Windows 7 Tutorial Index - F (1 of 3)
    F:
    Fan Speed Controller - Build your Own
    How to Create your Own Fan Speed Controller
    Fast User Switching- Enable or Disable
    How to Enable or Disable Fast User Switching in Vista and Windows 7
    FAT or FAT32 Volume - Convert to NTFS
    How to Convert a FAT or FAT32 Volume to NTFS in Windows 7
    Favorites - Add or Remove from Navigation Pane
    How to Add or Remove Favorites from the Windows 7 Navigation Pane
    Favorites - Add or Remove Recycle Bin
    How to Add or Remove Recycle Bin from Favorites in Navigation Pane in Windows
    Favorites - Change Default Icon in Navigation Pane
    How to Change Default Icon of Favorites in Navigation Pane in Windows 7 and Windows 8
    Favorites Empty in Navigation Pane - Fix
    How to Fix Empty Favorites in Windows Explorer Navigation Pane
    Favorites Favicon Icons - Reset in Start Menu and Internet Explorer
    How to Reset the Favorites Favicon Icons in Vista and Windows 7
    Favorites - Import and Export in Internet Explorer
    How to Import and Export Favorites in Internet Explorer
    Favorites Library - Create
    How to Create a "Favorites" Library with Correct Icon in Windows 7 and Windows 8
    Favorites - Links - Add or Remove in Navigation Pane
    Add or Remove "Favorites" Links in Navigation Pane of Windows 7 and Windows 8
    Favorites - Rename in Navigation Pane
    How to Rename "Favorites" in Navigation Pane in Windows 7 and Windows 8
    Favorites - Restore Default Favorite Links in Navigation Pane
    Restore Default Favorite Links in Navigation Pane of Windows 7 and Windows 8
    Favorites Shortcut - Create
    How to Create a "Favorites" Shortcut in Windows 7 and Windows 8
    Fax and Scan Shortcut - Create
    How to Create a "Windows Fax and Scan" Shortcut in Vista, Windows 7, and Windows 8
    Federated Search Providers
    Windows 7 OpenSearch Federation Providers
    Feed - Subscribe or Unsubscribe
    How to Subscribe or Unsubscribe to a RSS Feed in Internet Explorer
    Feeds - Import and Export in Internet Explorer
    How to Import and Export RSS Feeds in Internet Explorer
    File and Folder - Add "Compress" and "Decompress" to Context Menu
    How to Add NTFS "Compress" and "Decompress" to File and Folder Context Menu
    File and Folder - Add "Hide" and "Unhide" to Context Menu
    How to Add "Hide" and "Unhide" to File and Folder Context Menu in Vista, Windows 7, and Windows 8
    File and Folder - Add "Set and Unset as Read-only" to Context Menu
    How to Add "Set and Unset as Read-only" to File and Folder Context Menu in Windows 7 and 8
    File and Folder Arrangement - Change in Windows Explorer Window
    How to Change the File and Folder View Arrangement in Windows 7 Explorer
    File and Folder Arrangement - Group by - Sort by - Arrange by
    How to Change the Group by - Sort by - Arrange by Folder View in Windows 7 Explorer
    File and Folder Compression
    How to Compress and Decompress a Folder or File with NTFS Compression in Vista and Windows 7
    File and Folder Compression - Disable or Enable
    How to Disable or Enable NTFS Compression in Vista and Windows 7
    File and Folder - Copy as Path
    How to Copy the Full Path of a File or Folder in Vista and Windows 7
    File and Folder - Encrypt or Decrypt
    File and Folder - Hide or Unhide
    How to Hide or Unhide a File or Folder in
    File and Folder Lock Icon - Remove in Windows 7
    How to Remove the Lock Icon from Files and Folders in Windows 7
    File and Folder Permissions - Allow or Deny Users and Groups
    File and Folder - Read-only Attribute
    How to Set and Unset the Read-only File and Folder Attribute in Windows
    File and Folder - Rename from Command Prompt
    How to Rename a File and Folder from the Command Prompt
    File and Folder - Zip
    How To Zip (Compress) a File or Folder in Windows
    File - Delete from Command Prompt
    How to Delete a File in Windows from the Command Prompt
    File - Delete Undeletable File
    How to Delete an "Undeletable" File
    File Directory Context Menu - Add "Print File Directory" and "View File Directory"
    How to Add View and Print File Directory to the Context Menu in Vista and Windows 7
    File Details Properties - Add, Change, or Remove
    How to Add, Change, or Remove File Details Properties in Windows 7
    File Extension Icon - Change Default Icon
    How to Change the Default Icon of a File Extension in Windows 7
    File Extension Type - Associate a File Type or Protocol in Default Programs
    How to Associate a File Type or Protocol Default Program in Window 7
    File Extension Type - Restore Default Associations
    Restore Default Windows 7 File Extension Type Associations
    File Extension Type - Unassociate
    How to Unassociate a File Extension Type in Vista, Windows 7, and Windows 8
    File Extensions - Add "Hide - Show Known File Extensions" to Context Menu
    Add "Show/Hide Known File Extensions" to Context Menu in Vista, Windows 7, and Windows 8
  6. Posts : 72,062
       #15
    Windows 7 Tutorial Index - F (2 of 3)
    F:
    File Extensions - Hide or Show
    How to Hide or Show Known File Type Extensions in Windows 7
    File, Folder, Drive, or Registry Key - Take Ownership of
    File, Folder, Drive, or Program - Create Shortcut of in Windows
    File Menu - Restore or Remove
    How to Restore or Remove File from Windows Explorer Menu Bar
    File Name - Hide or Show for a Shortcut and Folder
    Hide or Show File Names of Shortcuts and Folders in Windows 7 and Windows 8
    File Names - Hide in Picture and Video Folders in Windows
    How to "Hide file names" of Files in Picture and Video Folders in Windows 7 and Windows 8
    File Sharing - Between XP and W7 (and vice versa)
    Create Shares Between XP and W7 (and vice versa)
    File Signature Verification
    How to Open and Use File Signature Verification in Vista and Windows 7
    File Types - Add or Remove from Index
    How to Add or Remove a File Type from the Windows 7 Index
    Files- Add "Hide - Show Hidden Files" to Context Menu
    How to Add "Show/Hide Hidden Files" to Context Menu in Vista and Windows 7
    Files and Folders - Context Menu - Add or Remove "Permanently Delete"
    How to Add "Permanently Delete" to the Context Menu of Files and Folders
    Files and Folders - Make Available Offline
    How to Make Network Files or Folders Available Offline in Windows 7
    Files and Folders - Open with a Single-Click or Double-Click
    Files and Folders - Recover with ShadowExplorer
    How to Recover Lost Files and Folders with ShadowExplorer
    Files and Folders- Restore with Previous Versions
    How to Restore Files and Folders in Windows 7 with Previous Versions
    Files and Folders - Select with Check Boxes in Windows Explorer
    How to Select Items with Check Boxes in Windows 7
    Files and Folders - Show or Hide Hidden Files and Folders
    How to Show or Hide All Hidden Files, Folders, and Drives in Windows 7
    Files and Screenshots - Upload and Post in Seven Forums
    How to Upload and Post a Screenshot and File in Seven Forums
    Files - Extract from a Windows 7 Installation DVD
    Files - Find All Encrypted Files on Local Hard Drives
    How to Find and See a List of All Encrypted Files on All Local Hard Drives
    Files waiting to be burned to disc - Stop Message
    How to Stop the "You have files waiting to be burned to disc" Message
    Find and Find Next - Registry Editor
    How to Use "Find and Find Next" in Registry Editor in Vista, Windows 7, and Windows 8
    Find on this Page - Use in Internet Explorer
    How to Use "Find on this Page" in Internet Explorer
    Firefox Advanced Browser Cleanup
    How to Clean up Firefox Settings Changed by Browser Hijacking Attacks
    Firefox and Chrome - Display Internet Explorer Only Websites
    How to Display IE-only Pages in Firefox and Chrome
    Firefox and IE9 - Allow or Prevent Websites to Request Your Location
    How to Allow or Prevent Websites to Request Your Location in IE9 and Firefox
    Firefox Auto Suggest - Enable or Disable
    How to Enable or Disable Auto Suggest in Firefox
    Firefox AutoComplete in Address Bar - Enable or Disable
    How to Enable or Disable AutoComplete in Firefox
    Firefox Automatic Updates - Enable or Disable
    How to Enable or Disable Firefox Automatic Updates
    Firefox Bookmarks - Export (Backup) and Import (Restore)
    How to Export and Import Bookmarks in Firefox
    Firefox Bookmarks - Import into Internet Explorer Favorites
    How to Import Firefox Bookmarks into Internet Explorer Favorites
    Firefox Browser Auto-Cleanup (How to Set)
    How to set Firefox's built-in Auto-Cleanup
    Firefox Button Icons - Change
    How to Change the Button Icons in Firefox
    Firefox - Change Default Download Save To Location
    How to Change the Default Download "Save to" Location in Firefox
    Firefox - Create and Run Multiple Profiles
    How to Create and Run Multiple Profiles Firefox
    Firefox - Customize Orange Bar
    How to Customize the Orange Bar in Mozilla Firefox
    Firefox - Disable New Tab Animation
    How to Disable New Tab Animation in Mozilla Firefox
    Firefox - DOM Storage Cookies - Enable or Disable
    Firefox "Downloads Complete" Alert - Turn On or Off
    How to Turn the "Downloads Complete" Alert On or Off in Firefox
    Firefox - Enable Aero Glass Transparency
    How to Have Firefox with Glass Transparency in Windows 7
    Firefox Favicons - Disable
    How to disable Favicons in Mozilla Firefox
    Firefox GPU Hardware Acceleration - Turn On or Off
    How to Turn GPU "Hardware Acceleration" On or Off in Firefox
    Firefox Master Password - Create, Change, or Remove
    How to Create, Change, or Remove a Master Password in Firefox
    Firefox - Menu Bar - Turn On or Off
    How to Turn the Menu Bar On or Off in Windows 7
    Firefox - Reducing Memory Usage
    How to Reduce Firefox Memory Usage in Windows 7
    Firefox Remember Passwords for Sites Exceptions - Remove
    How to See and Remove "Never Remember Password for This Site" Exceptions in Firefox
    Firefox Remember Passwords for Sites - Turn On or Off
    How to Turn On or Off Remember Passwords for Sites in Firefox
  7. Posts : 72,062
       #16
    Windows 7 Tutorial Index - F (3 of 3)
    F:
    Firefox - Reset to Default
    How to Reset Firefox to Default
    Firefox - Restore Previous Browsing Session
    How to Restore Previous Browsing Session in Firefox
    Firefox Saved Passwords for Sites - See and Remove
    How to See and Remove Saved Passwords for Sites in Firefox
    Firefox - Search from URL Bar
    How to Search Using Various Search Engines from the URL Bar in Firefox
    Firefox - Set Custom URL for New Tabs
    How to Set a Custom URL for New Tabs in Mozilla Firefox
    Firefox - Start Firefox in "Safe Mode"
    How to Start Firefox in Safe Mode
    Firefox - View Cache
    How to View the Mozilla Firefox Cache
    Firefox - Workarounds for Add-On incompatiblities with Firefox updates
    Various methods for getting incompatible Firefox Add-Ons to work in newer browser versions
    Flip 2D Shortcut Program
    Download "Flip 2D Shortcut" to Open CTRL+ALT+TAB in Windows
    Flip 3D - Add to Desktop Context Menu
    How to Add "Flip 3D" to the Desktop Context Menu in Vista and Windows 7
    Flip 3D - Change Number of Windows Displayed
    How to Change the Number of Windows Displayed in Flip 3D
    Flip 3D - Enable or Disable
    How to Enable or Disable Flip 3D in Vista and Windows 7
    Flip 3D Switch Between Windows Shortcut
    How to Create a Flip 3D Switch Between Windows Shortcut in Windows 7
    Floppy or Floppy Drive USB - Allow or Deny Read and Write Access
    How to Deny or Allow Read and Write Access to Floppy Drives in Vista and Windows 7
    Flush DNS Resolver Cache in Windows
    Folder and File Lock Icon - Remove in Windows 7
    Folder Background - Change
    How to Change the Folder Background with AveFolderBG for Windows 7
    Folder - Change Open Folder Icon
    How to Change the Open Folder Icon in Windows 7
    Folder Context Menu - Add "Empty Folder and Subfolders"
    How to Add "Empty Folder and Subfolders" to the Windows 7 Context Menu
    Folder - Delete Folder Content Context Menu
    Add "Delete Files in Folder" and "Empty Folder" to Context Menu of Folders in Windows
    Folder - Delete from Command Prompt
    How to Delete a Folder in Windows from the Command Prompt
    Folder, Drive, and Library - Pin to Start Menu
    Folder Icon - Change
    How to Change a Folder Icon in Vista and Windows 7
    Folder Icon - Change Default Icon
    How to Change Windows 7 Default Folder Icons using Resource Hacker
    Folder Icon - Change Windows 7 Default Folder Icon
    How to Change the Windows 7 Default Folder Icon
    Folder - Mount Drives or Partitions as
    Folder - Open in New Process
    How to Open Folder in New Process in Windows 7 and Windows 8
    Folder - Open in the Same or Own Separate New Window
    How to Open each Folder in the Same or Own Separate New Window in Windows 7
    Folder Options - Add or Remove Default Items from "View" Tab
    How to Add or Remove Default Items from Folder Options "View" Tab in Windows 7 and Vista
    Folder Options - Enable or Disable
    How to Enable or Disable Folder Options in Vista and Windows 7
    Folder Options - Open
    How to Open Folder Options in Windows 7
    Folder Options Shortcut - Create
    How to Create a "Folder Options" Shortcut in Vista, Windows 7, and Windows 8
    Folder or Shortcut Icon - Hide
    How to Hide a Folder or Shortcut Icon in Vista and Windows 7
    Folder - Pin or Unpin to Taskbar
    How to Pin or Unpin a Folder to the Taskbar in Windows 7 and Windows 8
    Folder Preview Picture - Change
    How to Change a Folder Preview Picture in Vista and Windows 7
    Folder Template - Change
    How to Change a Folder Template in Windows 7
    Folder Template - Default
    How to Set a Default Folder Template for All Folders in Windows 7
    Folder View - "Apply to Folders" with Same Folder Template
    How to "Apply to Folders" a Specific Folder View to All Folders with the Same Folder Template in Windows 7
    Folder View Arrangement - Group by - Sort by - Arrange by
    How to Change the Group by, Sort by, and Arrange by Folder View in Windows 7 Explorer
    Folder View - Change Icon Size in Windows Explorer
    How to Change the Icon Size in a Windows 7 Explorer Window
    Folder View - Reset All Folders
    How to Reset the Folder View Settings for All Folders with the Same Folder Template in Windows 7
    Folder View - Set a Default for All Folders
    How to Set a Default Folder View for All Folders in Windows 7
    Folder View Settings - Back Up and Restore in Windows
    How to Back Up and Restore Your Folder View Settings in Vista, Windows 7, and Windows 8
    Folder View Settings - Reset All to Default
    How to Reset All Folder View Settings to Default in Windows 7
    Folder Windows - Restore Previous Folder Windows at Logon
    How to "Restore Previous Folder Windows at Logon"
    Folders- "Empty Folder and Subfolders" - Add to Context Menu
    Folders - "Open in New Window" - Add or Remove from Context Menu
    How to Add or Remove "Open in new window" in Windows 7 Context Menu
    Font Settings Shortcut - Create
    How to Create a Font Settings Shortcut in Windows 7 and Windows 8
    Fonts - Change
    How to Change the Default Fonts in Windows 7
    Fonts - Delete
    How to Delete Fonts in Windows 7 and Windows 8
    Fonts - Enable or Disable Smooth Edges of
    How to Enable or Disable "Smooth Edges of Screen Fonts"
    Fonts - Install
    How to Install a Font in Windows 7 and Windows 8
    Fonts - Preview
    How to Preview Fonts in Windows 7 and Windows 8
    Fonts - Show and Hide
    How to Show and Hide Fonts in Windows 7 and Windows 8
    Force DVI/HDMI resolutions and refresh rates
    How to Force DVI or HDMI Resolutions and Refresh Rates in Windows 7
    Forgotten Password Wizard Shortcut - Create
    How to Create a "Forgotten Password Wizard" Shortcut in Vista, Windows 7, and Windows 8
    Format a HDD or USB
    How to Quick Format a HDD or USB Drive
    Format - Clean and Clean All a Hard Disk with Diskpart Command
    Format Regional Language - Change
    How to Change the Regional Language Format in Windows 7 and Windows 8
    Formats - Restore Default Region Settings
    How to Restore the Default Regional Format Settings in Windows 7 and Windows 8
    "Formats" Tab in Region and Language - Add or Remove
    How to Add or Remove the "Formats" Tab in Region and Language
    "Found New Hardware" Balloons - Enable or Disable
    How to Enable or Disable "Found New Hardware" Balloons During Device Installation
    FTP Server - Set Up on Your Computer
    How to Set Up a FTP Server On Your Computer
    Full Screen F11 Mode - Enable or Disable Auto-Hide in Windows Explorer and Internet Explorer
    How to Enable or Disable "Auto-Hide" in Vista and Windows 7 Explorer Full Screen F11 Mode
  8. Posts : 72,062
       #17
    Windows 7 Tutorial Index - G (1 of 2)
    G:
    Gadgets - Add or Remove from Desktop
    How to Add or Remove Desktop Gadgets in Windows 7
    Gadgets - Add or Remove from Desktop Context Menu
    How to Add or Remove "Gadgets" from Desktop Context Menu in Windows 7
    Gadgets - Allow or Prevent Installation of Unsigned Gadgets
    How to Allow or Prevent Installation of Unsigned Gadgets in Windows 7
    Gadgets - Allow or Prevent User Installed Gadgets
    How to Allow or Prevent User Installed Gadgets in Windows 7
    Gadgets - Change "Get more gadgets online" Link
    How to Change the "Get more gadgets online" Link in Windows 7
    Gadgets - Create a Custom Clock Gadget
    How to Create a Custom Clock Gadget
    Gadgets - Customize
    How to Customize Existing Windows 7 Gadgets
    Gadgets - Enable or Disable
    How to Enable or Disable Gadgets in Windows 7 and Vista
    Gadgets - Hide or Show on Desktop
    How to Hide or Show Desktop Gadgets in Windows 7
    Gadgets - How to Move Them Closer Together
    Trick to Moving Gadgets in Windows 7 Closer Together
    Gadgets not Displaying Correctly in Windows 7 - Fix
    How to Fix Gadgets not Displaying Correctly in Windows 7
    Gadgets - Restore Default Gadgets
    How to Restore the Default Windows 7 Gadgets
    Gadgets Shortcut - Create
    How to Create a "Gadgets" Shortcut in Windows 7
    Gadgets - Turn On or Off
    How to Turn Windows 7 Gadgets Feature On or Off
    Game Controllers Shortcut - Create
    How to Create a "Game Controllers" Shortcut in Windows 7 and Windows 8
    Games Explorer - Automatic Game Updates - Enable or Disable
    Enable or Disable Game Updates in "Games Explorer" in Vista, Windows 7, and Windows 8
    "Games" Explorer - Change Default Icon in Start Menu
    How to Change the Default "Games" Explorer Icon in the Windows 7 Start Menu
    Games Explorer - Downloading Game Information - Enable or Disable
    Enable or Disable Downloading Game Information in "Games Explorer" in Vista, Windows 7, and Windows 8
    Games Explorer - Edit
    Edit Games Explorer Easily with Game Explorer Builder
    Games Explorer Folder - Add Games To
    How to Add a Game to Games Explorer Folder in Vista, Windows 7, and Windows 8
    Games Explorer Folder - Add Steam Games to
    How to Add Steam Games to Windows 7 Games Explorer Folder
    Games Explorer Folder - Customize Context Menu
    How to Customize the Windows 7 Games Explorer Context Menu
    Games Explorer Folder - Delete a Game
    How to Delete a Game in Games Explorer Folder in Vista, Windows 7, and Windows 8
    Games Explorer Folder - Hide or Unhide Games
    Hide or Unhide Games in Games Explorer Folder in Vista, Windows 7, and Windows 8
    Games Explorer Folder - Restore Default Games
    How to Restore the Default Games in Windows 7 Games Explorer Folder
    Games Explorer - Last Play Time of Games - Enable or Disable
    Enable or Disable Last Play Time of Games in "Games Explorer" in Vista, Windows 7, and Windows 8
    Games Explorer Shortcut - Create
    How to Create a "Games Explorer" Shortcut in Vista, Windows 7, and Windows 8
    Games Library - Create
    How to Create a "Games" Library with Correct Icon in Windows 7 and Windows 8
    Game Restrictions - Set in Parental Controls
    How to Set Game Restrictions in Windows 7 Parental Controls
    Gathering a Startup, Shutdown, Sleep, Hibernate, or Reboot Trace
    Getting Traces to Troubleshoot Performance Issues
    Get Programs - Create "Install Program from Network" Shortcut
    How to Create an "Install Program from Network" Shortcut in Vista, Windows 7, and Windows 8
    Get Windows 10 app - Cancel Reservation for Free Upgrade to Windows 10
    How to Cancel Reservation for Free Upgrade to Windows 10 in Get Windows 10 app
    Get Windows 10 app - Check Compatibility Report for Windows 10
    Check Get Windows 10 app Compatibility Report for Windows 10 in Window 7 and 8.1
    Get Windows 10 app - Reserve Free Upgrade to Windows 10 in Windows 7 and 8.1
    How to Reserve Free Upgrade to Windows 10 using 'Get Windows 10' app in Windows 7 and 8.1
    Get Windows 10 Icon - Remove from Taskbar in Windows 7 and 8.1
    How to Remove 'Get Windows 10' Reserve Icon from Taskbar in Windows 7 and 8.1
    Getting Started Shortcut - Create
    How to Create a Windows 7 "Getting Started" Shortcut
    GMail Drive - Use 8GB as Local Storage
    How to Use GMail Drive 8GB as Local Storage
    Google Chrome - Add Extensions
    How to Add Extensions to Google Chrome Browser
    Google Chrome - Applying a Theme
    How to Apply a Theme to your Google Chrome Browser
    Google Chrome - Change Default Download Location
    How to Change the Default Download Location in Google Chrome
    Google Chrome - Create Desktop Shortcut of Website
    How to Create a Desktop Shortcut of Website in Google Chrome
    Google Chrome - DownTheMall Alternative
    How to Get a DownTheMall Alternative for Google Chrome
    Google Chrome Home Button - Hide or Show in Windows
    How to Hide or Show Home Button in Google Chrome for Windows
    Google Chrome Homepage - Change in Windows
    How to Change Homepage in Google Chrome for Windows
    Google Chrome - Import and Export Bookmarks
    How to Import and Export Bookmarks in Google Chrome Browser
    Google Chrome - Import Favorites from Internet Explorer
    How to Import Internet Explorer Favorites into Google Chrome Browser
    Google Chrome Proxy Settings - Change to Speed Up
    How to Speed Up Google Chrome with Proxy Settings
    Google Chrome - Reopen Last Browsing Session
    How to Reopen the Last Browsing Session in Google Chrome Browser
    Google Chrome - Reset Theme to Default
    How to Reset to Default Theme in Google Chrome Browser
  9. Posts : 72,062
       #18
    Windows 7 Tutorial Index - G (2 of 2)
    G:
    Google Chrome - Reset to Default
    How to Reset Google Chrome Browser to Default
    Google Chrome Startup Page - Change in Windows
    How to Change Startup Page in Google Chrome for Windows
    Google Chrome - Turn Bookmarks Bar On or Off
    How to Turn the Bookmarks Bar On or Off in Google Chrome
    Google Chrome Website Notifications - Allow or Block in Windows
    How to Allow or Block Website Notifications in Google Chrome in Windows 7, Windows 8, and Windows 10
    Google Drive - Add to "Send To" Context Menu
    How to Add Google Drive to "Send To" Context Menu in Windows
    Google Search Display Issue in Internet Explorer 11 - Fix
    How to Fix Google Search and Google+ Notifications Not Loading Properly in IE11
    Google Updater - Reschedule or Disable
    How to Reschedule or Disable Google Updater
    GPT Disk - Convert from MBR Disk
    How to Convert a MBR Disk to a GPT Disk
    GPT Disk - Convert to MBR Disk
    How to Convert a GPT Disk to a MBR Disk
    GPU Hardware Acceleration - Turn On or Off in Chrome
    How to Turn GPU "Hardware Acceleration" On or Off in Chrome
    GPU Hardware Acceleration - Turn On or Off in Firefox
    GPU Hardware Acceleration - Turn On or Off in Internet Explorer
    How to Turn GPU "Hardware Acceleration" On or Off in IE9 and IE10
    Graphics Card - Flash NVIDIA BIOS
    How to Flash the BIOS on an NVIDIA Graphics Card
    Graphics Card - Install New Card
    How to Install a New Graphics Card
    Graphics Card - Overclock
    How to Overclock a Graphics Card
    Graphics Card Problems - Diagnose
    Help Diagnose Graphics Card Problems
    Graphics Card - Stress Test with Furmark
    How to Stress Test a Video Card with Furmark
    Graphics Card - Test NVIDIA/AMD with OCCT
    How to Test NVIDIA/AMD Performance with OCCT
    Group by - Sort by - Arrange by - Change File and Folder View Arrangement
    Group Policies - Apply to All Users Except Administrators
    How to Apply Local Group Policies to All Users Except Administrators
    Group Policy - Apply to a Specific User or Group
    How to Apply Group Policies to a Specific User or Group in Vista, Windows 7, and Windows 8
    Group Policy - Backup and Restore in Windows
    How to Back Up and Restore Local Group Policy in Windows
    Group Policy Editor - Add to Control Panel
    How to Add Local Group Policy Editor to Windows 7 Control Panel
    Group Policy Editor - Open
    How to Open the Local Group Policy Editor in Windows 7 and Windows 8
    Group Policy Editor - Quickly View Enabled Policies in Windows
    How to Quickly View Enabled Group Policies in Windows
    Group Policy - Reset to Default
    How to Reset Local Group Policy to Default in Vista, Windows 7, and Windows 8
    Group Policy Settings - Force Update in Windows
    How to Force Group Policy Updates to be Applied Instantly in Windows
    Grouped Taskbar Icon Button - Cascade
    How to Cascade All Windows in a Windows 7 Grouped Taskbar Icon
    Grouped Taskbar Icon Button - Close all windows
    How to Close All Windows in a Windows 7 Grouped Taskbar Icon
    Grouped Taskbar Icon Button - Restore all windows
    How to Restore All Windows in a Windows 7 Grouped Taskbar Icon
    Grouped Taskbar Icon - Windows Stacked or Side by Side
    How to Show Windows Stacked or Side by Side in a Windows 7 Grouped Taskbar Icon
    Groups - Add or Remove User Accounts from being a Member of
    How to Add or Remove User Accounts from Groups in Vista, Windows 7, and Windows 8
    Groups and Users - Allow or Deny Permissions
    Groups - Create New or Delete
    How to Create and Delete a User Group in Windows 7 and Vista
    Guest Account - Change Name
    How to Rename "Guest" Account in Vista, Windows 7, and Windows 8
    Guest Account - Turn On or Off
    How to Turn the Guest Account On or Off in Windows 7
    GUI Boot - Enable or Disable in Windows
    How to Enable or Disable "GUI Boot" in Windows
    GUID (CLSID Key) Shortcuts List for Windows 7
    GUID - Generate in Windows
    How to Generate a New GUID or UUID in Windows
  10. Posts : 72,062
       #19
    Windows 7 Tutorial Index - H (1 of 2)
    H:
    Hard Disk AHCI Link Power Management - Enable HIPM and DIPM
    How to Enable HIPM and DIPM for your SSD and HDD in Windows 7 and Windows 8
    Hard Disk - Clean and Clean All with Diskpart Command
    Hard Disk Partition Letter Missing in Windows 7 - Fix
    How to Fix Missing Vista Hard Disk Partition Letter in Windows 7
    Hard Disk Space - Free Up and Recover
    Hard Disk Quota - Set Space Limits for Users
    How to Set Disk Quota Limits for Users in Windows 7 and Vista
    Hard Drive - Change (Laptop)
    How to change the Hard Drive in your laptop
    Hard Drive - Convert Basic Disk to a Dynamic Disk
    How to Convert a Basic Disk to a Dynamic Disk
    Hard Drive - Convert Dynamic Disk to a Basic Disk
    Hard Drive - Convert FAT or FAT32 Volume to NTFS
    Hard Drive - Convert GPT Disk to MBR Disk
    Hard Drive - Convert MBR Disk to GPT Disk
    Hard Drive - GPT or MBR
    How to Quickly and Easily Tell if Your Hard Drive is Formatted GPT or MBR
    Hard Drive - Recover Deleted Partitions in Windows
    Hard Drive Serial Number - Find in Windows
    How to Find Serial Number of Hard Drive in Windows 7, Windows 8, and Windows 10
    Hard Drive Space - Free Up and Recover
    Hard Drive - Turn Off Hard Disk After Idle or Never
    Hard Drives - Lock a Drive Letter
    Hardware and Devices Troubleshoot Shortcut - Create
    How to Create a "Hardware and Devices Troubleshoot" Shortcut in Windows 7
    Hardware Identification
    This is a guide to help you identify unknown hardware
    Hardware System Properties Shortcut - Create
    Create a "Hardware System Properties" Shortcut in Vista, Windows 7, and Windows 8
    Hardware Tab - Add or Remove from Properties
    How to Add or Remove the "Hardware" Tab from Properties in Vista, Windows 7, and Windows 8
    HDD or USB - Quick Format
    Help and Support - Change Default Icon in Start Menu
    How to Change the Default "Help and Support" Icon in the Windows 7 Start Menu
    Help and Support Shortcut - Create
    How to Create a "Windows Help and Support" Shortcut
    Help Experience Improvement Program - Join or Unjoin
    How to Join or Unjoin the Windows 7 Help Experience Improvement Program
    Help (.hlp) Files - Cannot Open in Windows Fix
    How to Open 32-bit Help (.hlp) Files that Require WinHlp32.exe in Windows
    herdProtect: Malware Detection
    Scan for malware using the herdProtect multi-engine cloud service
    Hibernate - Change Size of hiberfil.sys File
    How to Change the Size of the hiberfil.sys File in Windows 7 and Windows 8
    Hibernate Computer - Allow or Prevent Users and Groups
    How to Allow or Prevent Users and Groups to Hibernate, Restart, Shut Down, and Sleep the PC
    Hibernate - Enable or Disable
    How to Enable or Disable Hibernate in Windows 7 and Windows 8
    Hibernate Shortcut - Create
    How to Create a "Hibernate" Shortcut in Windows
    Hibernate, Shut Down, Restart, and Sleep Commands - Add or Remove
    How to Add or Remove the Shut Down, Restart, Sleep, and Hibernate Commands in Windows 7
    Hidden Files - Add "List Hidden Files" to Context Menu
    How to Add "List Hidden Files" to Context Menu in Vista, Windows 7, and Windows 8
    Hidden Files and Folders - Show or Hide
    Hidden Files and Folders Option - Add or Remove
    How to Add or Remove "Hidden Files and Folders" from Folder Options in Vista and Windows 7
    Hide and Unhide a File and Folder - Add to Context Menu
    How to Add "Hide" and "Unhide" to File and Folder Context Menu in Windows 7
    "Hide" and "Unhide" a File and Folder in Windows
    How to Hide or Unhide a File or Folder in Vista, Windows 7, and Windows 8
    Hide or Show File Name of a Shortcut and Folder
    Hide - Show Hidden Files - Add to Context Menu
    How to Add "Show/Hide Hidden Files" to Context Menu in Vista, Windows 7, and Windows 8
    Continued on next page......
